1325 atc cnc machine with automatic loading and unloading platform
#Working Area 1300x2500x200mm
#Spindle ATC 9.6KW Italy original HSD spindle, ES951 Model. 6000-24000RPM
#Control system Taiwan SYNTEC 60WE control system with MPG handle wheel, more precision
#Drive systemJapan YASKAWA 850W servo motor and drivers, Z axis with brand brake.
#Japan Shimpo reducer.
#Inverter Taiwan Delta B Model 11.0KW
#Machine Frame New type thicker and bigger heavy duty 8 mm
#Working table Vacuum table with T slot, 4 Zones
#Tool Magazine 12 pieces with Carousel Tools Changer
#Guide railTaiwan PMI linear guide, 25#
#TransmissionX,Y-helical rack pinion, Z axis with 2505 TBI ball screw
#Tool sensorAutomatic tool sensor
#CollectISO30 tool holders with ER32 collect
#Lubrication system Automatic lubrication system for rails
#Traveling speed 65m/min
#Working speed 25m/min
#Voltage 380V,3phase, 50HZ
#Limited switch Japan Omron limited switch
#Electric part French SCHNERDER switch
#Electric Wires High soft shield with copper wire to protect against static electricity, UL/CE standard Shanghai Cardiff brand
#Vacuum Pump German KVT3.140 4.0KW Becker vacuum pump
#Dust Collector 1.5kw double bags dust collector system. Europe CE standard
#Drilling Head Italy HSD 9 vertical type
