585,996 active members*
5,070 visitors online*
Thread: CNC package
Results 1 to 9 of 9
    CNC package
    pls check our cnc package here
    http://www.kelinginc.net/CNCPackage.html
    Video
    Here is the video from Dave for the package
    http://youtube.com/watch?v=vR74JnEB9Rk
    Oct 2007
    152
    hi, last saturday I have sent you an Email about the CNC 3 Axis Package with 495 oz-in motor and KL-4030 Driver and I haven't receive any answer yet, I don't know if this forum is the only way to reach you. Anyway I am posting my question here, hoping to get an answer:
    Hi, I am interested about the CNC 3 Axis Package with 495 oz-in motor and KL-4030 Driver. Right now I have the parts for the power supply which is a
    Triad Magnetics Transformer, chassis mt, pri:115VAC, sec:24VAC, 10A, leads, 50/60Hz date sheet:
    http://www.alliedelec.com/Images/Pro...TIC/F-401U.pdf
    A capacitor : Mallory 2200UF 40 VDC Max surge 50VDC part number:658-0712-158 data sheet: http://www.alliedelec.com/Search/sea...003984617F&i=3
    Bridge rectifier 1000V 400A 700V 35A Surface mount data sheet:
    http://www.alliedelec.com/Search/sea...003984617F&i=1
    Resistor: 1 watt at 2 km
    I would like to know if with these part for the power supply I can avoid buying the power supply that is included in the package and is it compatible.
    If so what is your price for the package + S/H to Canada by USPS, my postal code G9N6T5.
    Thank you
    Pls send us a email for your quote: [email protected]
    Mar 2004
    1147
    bobinette,
    the kl4030 should not be run at more than 34-26ish volts. if yuou keep your power supply below that, and use set the amperage correct on your drives for your motors, you should be ok.
    the PSU that comes with the kelling kit can make a machine move just fine, but it sounds like what you have proposed is much more appropriate.
    the biggest impact upgrade i can see for my machine will be a PS. i have keling4030s and the 24v PSU they provide with their 425oz/in kit.
    Hope that helps.
    Design & Development
    My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
    Oct 2007
    152
    Hi, thanks for the info, haven't made up my mind yet on the 305 package from Hobby CNC and the the 495 from Kelinginc with the drive 4030, I don't see the PC10 selling alone. About the voltage can it be adjusted on the 4030 drive
    Mar 2006
    113
    I've got the same 495 keling 4 axis kit set up on my machine. Several others including vacpress and watson studios have the kit and use the power supply and that seemed like the weak link. As the keling specs for the 4030 drivers state that they are rated at 40v. I bought a power supply kit from hubbard cnc on ebay, great supplier and the ps puts out ~38v and has worked flawlessly. I haven't taken the keling power supply out of the box and I will probably sell it, the kit seems like the best price so get it and buy or build the upgraded ps and you wont regret it.
    Brian
    Mar 2004
    1147
    bobbinette- i just looked at your transformer spec.. i would recommend a 36v transformer, or even 40ish... 38 would be ideal..
    the risk of destroying the drives goes up.
    my machine can move a 1.5tpi ballscrewwith 5:1 reduction at 120ipm
    Not so bad. i lookforward to a new PSU eventually adding upto 20% more speed with similar torque.
    my speeds are actually higher with lower amperages set on the drives.. less back emf causing lost steps at high speed, or so i am guessing. i am hoping the higher voltage does a better job at higher amperages.
    a win win if you get a bigger PSU.. most likely.
    Nov 2007
    197
    can you post up a link to the power supply you bought?
    can't seem to locate it on ebay.
    i just picked up the 425oz kit, but was wondering about the PS
    thanks!
  1. Cad/Cam package
    By Todd Price in forum Uncategorised CAM Discussion
    Last Post: 06-11-2007, 03:52 PM
  2. CNC Package
    By automationtechinc in forum News Announcements
    Last Post: 03-29-2007, 02:06 AM
  3. candcnc package or other??
    By 2fst4u in forum Waterjet General Topics
    Last Post: 11-27-2006, 08:55 PM
  4. Hardware Package
    By jhwatts in forum LinuxCNC (formerly EMC2)
    Last Post: 12-26-2005, 05:27 AM
  5. another package
    By Laff Riot in forum Uncategorised CAM Discussion
    Last Post: 06-07-2003, 09:28 PM
