585,942 active members*
3,204 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > UCCNC Control Software > Intermittent Issue With Z Probing Direction - UCCNC & UC300ETH-LPT5
    Aug 2017
    Using a CNCRouterParts PRO4848, I recently converted from the standard Smoothstepper/Mach3 to UCCNC and the UC300ETH-LPT5 with UCCNC Screenset 2017. I'm using the probing macro supplied in this thread...
    https://www.cnczone.com/forums/cnc-r...-software.html
    Conversion was fairly uneventful and everything initially work very well. A few weeks ago, I was measuring tool length using "Auto Zero Initialize" and the tool started moving upwards. I checked all the setting and confirmed that nothing changed. Restarted UCCNC with no change. Shut down and restarted everything and still had the same problem. I needed to cut a project , so I just set the Z-workpiece manually. Everything cut fine, so I'm sure it's strictly a probing based issue. When I tried again a few days later, probing worked as expected. Well it happened again yesterday and I'm scratching my head. Any ideas?
    Re: Intermittent Issue With Z Probing Direction - UCCNC & UC300ETH-LPT5
    So, it worked fine for a while, and then started going backwards?
    Did anything change in your system?
    Do you by chance have a CNC Drive pendant? A small number of people with these pendants have had issues with the probing macros.
    I don't believe I've ever heard of this happening to anyone.
    The way the probing works, is the macro first reads the Z axis DRO. It then subtracts the Firs Probe Distance, and tells the machine to probe to that position. So it should always probe downwards.
    When it's moving up, is the Z axis DRO value increasing?
    Do you ever have any other issues with Z axis direction? A bad connection on the Z axis dir wire could possibly cause this.
    Can you post a screenshot of the Auto Zero settings, and the run screen DRO's when you start to probe?
    Aug 2017
    ...Do you by chance have a CNC Drive pendant? A small number of people with these pendants have had issues with the probing macros....
    Thanks for the reply Gerry. I really like your Screenset.
    Yes. I am using a VistaCNC iMach3 P4-S. I hadn't thought of this as a possible cause. I do use the pendant to move to the tool measurement position. Have you seen any resolution to the probing macro when used with a pendant?
    DRO values work as expected.
    Try disabling the pendant plugin and see if the probing will then work correctly. Restart UCCNC after disabling the pendant.
  1. UC300ETH-UB1 / Gecko G540 / UCCNC Ports and Pins?
    By GEBrown in forum Controller Cards
    Last Post: 08-16-2018, 01:05 PM
  2. UCCNC and UC300ETH-5LPT configuration issue
    By dalai in forum UCCNC Control Software
    Last Post: 03-20-2018, 10:37 AM
  3. Not getting any input from PC to CNC Router - UCCNC UC300ETH UB1
    By crash416 in forum DIY CNC Router Table Machines
    Last Post: 11-03-2017, 12:49 AM
  4. Converting to UCCNC & UC300ETH-LPT5 (From Mach3/PP/SS)
    By Mogal in forum UCCNC Control Software
    Last Post: 04-08-2017, 08:06 PM
  5. Intermittent issue with axis reversing direction after Homing
    By spank in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-30-2013, 01:53 AM
