585,973 active members*
4,065 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > I smoked my HY VFD a month ago. Here is what happened.
Results 1 to 14 of 14
    Jun 2013
    443
    I actually thought it was because I was running my spindle at low speed (12000rpm) with a 43mm bit taking a few mm off my spoil board. I thought, that the spindle had become hot inside and shorted out somewhere because I noticed a "spark" in the air. The outside of the spindle was just slightly warm.
    But sparks are fast, circuit breakers not far behind. The HY VFD, actually caught fire inside. I watched the fire for a wee while (as us men do) before it went out.
    Heres the thing. Immediately after the event (and the fire inside the VFD going out) I disconnected the shielded output lead off the VFD and put a meter on it to see where or if the spindle was shorted. It all measured about 2.5ohms between all phases. Open circuit to ground. Visual inspection of the plug, lead, I am anal I looked. Obviously not enough.
    I bought a new HY VFD. Before I plugged it in, I megga checked the lead with 1000v. I wired the new VFD in, and have run the setup for about 3 hours while I make a new Z Axis (I decided to upgrade my spindle) to accept a larger motor. Yesterday, CRACK, same deal without the fire in the VFD. This time a 6mm bit not even working hard.
    Again, meter on the lead. 2.5 ohms between phases. Pull the plug off, and now I see the issue. This lead, still measures open circuit between phases. Still megga checks fine. Hold it, twist it, keep that 1000v onto it, no problem. But occasionally and thats enough, it has an internal short inside. I guess this is "hey look what happened to me". I am not concerned today I am going to install a new plug to see if my setup still runs. The VFD powered up yesterday without the motor connected. Strange that the short is intermittent but thats life.
    15362
    Re: I smoked my HY VFD a month ago. Here is what happened.
    Quote Originally Posted by boydage View Post
    For starters you have the incorrect cable for the VFD Drive to the Spindle you should not have an open Ground cable, this needs to be a 4 wire shielded cable
    Is the Spindle plugs 4th Pin have Ground continuity to the Spindle body, most are not connected inside and this need to be corrected
    Mactec54
    Jun 2013
    443
    I made this lead about 8 years ago. Its a 3 core 15A extension cable, and also a single 2.5mm green conductor that I used for an earth. This I pushed through a SS braid to encase the 4 conductors. So in effect, the phase wires are double insulated, and in my mind shielded.
    The ss shield and green wire, green is connected to the earth pin on my new spindle.
    Earth is common throughout the whole machine, right back to the live earth I have next to my main meter box. I have bonding leads to the nana. I am pretty confident it is well earthed and shielded. I also have a filter. I should throw up a pic. The short inside that plug was phase to phase. Actually I will throw up a pic, if I have done something wrong its good to know.
    Hey out of interest - the settings I put into that new spindle. The last one off memory was 120 - 120 anti stall protection. I was unable to stop the spindle. I set it down to 100 to also find I was unable to turn the spindle off. So I set it to zero. What do you reckon?
    Jun 2013
    443
    Oh. And to note,I have installed a new spindle. Much nicer plug. They call it an aviation plug but in the 11 years I was a lame I never saw one like it ha. But it was a good one.
    Dec 2003
    24221
    If that is the new plug, then it sounds like it might be a MS (Military Style) connector, normally very $$$ pricey to purchase!
    Part No's are preceded by MS.
    Al.
    Albert E.
    15362
    Al.
    They could only wish that they where MS quality connectors, they are a very poor copy of what is known as aviation style connectors you can buy them for around a $1 each shipped
    Mactec54
    15362
    That can work if the shield is covered if not the shield can cause some nasty shocks if you touch it at the wrong time, it's not advisable to use a shield that is not covered
    Setting the anti stall parameter has nothing to do with how the spindle turns off, and it must be set to a number that is safe for your spindle 120% is max for these spindles, 0 would give you no protection
    Yes that is quite common to get a short between 2 phase in these plugs, if you have not wired it correctly, you did not say you had a short in your first post
    So you got away with it for 8 years if it had been correctly wired it would most likely been still running for many more years to come
    Mactec54
    Jun 2013
    443
    "So you got away with it for 8 years if it had been correctly wired it would most likely been still running for many more years to come"
    Darn. There was a time I thought you might be the VFD guru. After that statement, now I dont.
    15362
    Your Ignorance has the best of you, it would help to educate yourself on the subject before you hurt someone or yourself
    Electrical extension cord is not suitable for a 3Phase VFD to Spindle connection and would not meet code requirements
    You megger checked a cable at a 1000v that would not of been rated for a 1000v I'm sure that would of showed leakage after 8 years of use with the VFD Drive, it should of been replaced with the correct cable but ignorance takes over and you know best which does not bother anyone here just paints a picture of who you are
    Mactec54
    Aug 2009
    1573
    ...Plugs are always a weak point. get rid of it if possible.
    https://www.google.com/search?client...terminal+strip
    Nov 2011
    205
    It Has to be right --- I saw it on the INTERNET !!!!!!!!!!!!!!!
    Don
    Sep 2009
    99
    Hi boydage,
    I use about 10 of these in my factory. We face issues with the connectors once in a while.
    The photo you've shared appears to be the same issues we've faced. Whenever we face this we replace the connector on the spindle as well as on the cable and things become OK with that. If we do not change the connectors on either side we end up with repeat failures as you have.
    Best of luck!
    Jaideep
    Nov 2008
    522
    I started to switch over to those aviation connectors. But they're really not very good TBH. They were never intended to be inline, so one side has no insulation or strain relief. I did about the best job possible with heatshrink but I think it was still way more janky than the average connector. It also didn't handle the thick gauge of wire I was using to handle power. I don't recall numbers, but it's intended for pretty thin stuff.
    Jun 2013
    443
    Quote Originally Posted by MechanoMan View Post
    Having been an aircraft engineer a lifetime ago the MS is military standard. Along with the AN which is army navy standard. Although at no time, in all the years I worked on aircraft, have I seen connectors as poorly made. A real MS electrical connector is quite something else to put together.
    Out of interest, the Chinese heavier duty spindle I just bought did actually have quite a good connector I was both surprised and pleased with it. ha
  1. Bridgeport Boss 5 smoked
    By AThayer in forum Bridgeport / Hardinge Mills
    Last Post: 12-26-2016, 01:48 AM
  2. I just smoked the second stepper - help!
    By stargeezer in forum Stepper Motors / Drives
    Last Post: 06-01-2015, 06:34 PM
  3. Arrow 500 - first plugin and smoked it !
    By nzben in forum Cincinnati CNC
    Last Post: 04-13-2012, 08:11 PM
  4. Smoked POWER SUPPLY
    By Clawsie Machine in forum Cincinnati CNC
    Last Post: 06-10-2011, 01:38 PM
  5. Whoops! Smoked all 4 channels?
    By Riceburner98 in forum Xylotex
    Last Post: 07-15-2007, 03:36 AM
