585,925 active members*
3,370 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mitsubishi controls > Help Needed! Mitsubishi QA20 in metric units
    Feb 2013
    11
    How do i change machine units from metric to inch for a QA20 Mitsubishi EDM?
    It started in metric units after a system restore, a walk through available manuals produce no parameter number to change.
    Please Help.
    Em.
    Apr 2004
    5737
    Re: Help Needed! Mitsubishi QA20 in metric units
    Try entering G20.
    Andrew Werby
    Website
    Feb 2013
    11
    Thanks for your reply Awerby.
    I'll do that, but will it change only for the program running or about to run.
    Or am I mistaken?
    Have a nice weekend.
    Feb 2013
    11
    G20 code did not work but the following procedure did:
    E-stop the machine, but not tun it off.
    goto maintenance/switches/switch screen 2
    select INCH from the top left, optionaly elect X0.1 to get 5 decimal precision.
    turn machine off with red off button, wait until it fully shuts down.
    turn it back on with green button and you will see it working on inch units.
    Good Day.
  1. Has anyone used metric units with PathPilot?
    By TurboStep in forum Tormach PathPilot™
    Last Post: 03-26-2015, 11:53 AM
  2. Mixing english and metric units in CAMBAM?
    By Garage Elf in forum CamBam
    Last Post: 11-22-2012, 12:50 AM
  3. Replies: 7
    Last Post: 02-14-2012, 03:58 PM
  4. plans in metric units
    By onekk in forum Commercial CNC Wood Routers
    Last Post: 05-04-2010, 06:21 PM
  5. Sprutcam post processor for metric units
    By sotos in forum Syil Products
    Last Post: 06-07-2007, 10:15 PM
