Re: Need help with programming OSP7000 1999
hy it's cheaper if you can do it; you will also need to edit some parameters, so to lower acceleration & breaking, maximum rpm , static torque for c axis, and maybe others, but i don't know where are those for your machine
i would avoid the adapter, and craft the entire piece instead
why do you wish to increase the chuck size ? custom jaws aren't enough ? pressure should be similar for both, arround 2.7mpa, but, if you wish to increase it for the 12", then check if the hydra cilinder can raise up to the task, and don't forget to restore it when you'll go back to the 8" / kindly
