hello! i have a problem with a turret motor at a mazak cnc.i changed the motor because the ax was broken( broken teeth ).after this change i determined that at every changed position of turret ,the motor tends to came back whith a small movement.sometimes overload alarm occur.so, how can i fix this problem? there is a parameter to be modified for this?P.S. the motor which i changed it was new!Thank you!
