585,589 active members*
2,918 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > What board is the RS-232 function on?
Results 1 to 10 of 10
    Mar 2010
    1852
    I have a 1996 VF-2 that will not send programs back to the computer. It was that way since the day I got it about 5 years ago. I would like to get this fixed and I want to know what board the RS-232 function is on.
    It receives programs fine, but when you attempt to send, it beeps but nothing gets sent or maybe a few characters. To save a program I have to send it to the floppy drive and take it to the computer by hand.
    Can someone tell me please?
    Thanks in advance----Mike
    Aug 2009
    1570
    Re: What board is the RS-232 function on?
    Mar 2010
    1852
    Quote Originally Posted by machinehop5 View Post
    Why are you sending me to a BobCad site to fund out what board it is on, they know nothing about Haas electronics. I have been running Haas mills for thirty years, I know how to hook them up and do all of my own repairs, have not seen a Haas tech since about 1998. What BOARD is the RS-232 electronics on?
    Thanks---Mike
    Nov 2005
    56
    Quote Originally Posted by Machineit View Post
    Thanks---Mike
    There is no need to be rude, I would have thought someone with your apparent experience would be fully aware of what board the RS232 is on!
    Before blaming the machine make sure your RS232 setting are the same on both the machine and whatever your using to send and receive programs.
    If everything is ok and you do suspect a faulty board it's on the other side of the connector you plug into on the electrical cabinet. A machine of that vintage should have 2, try swopping the boards around.
    Graeme
    Mar 2010
    1852
    Obviously, based on the answers I am receiving, I am unable to properly explain the problem. So please disregard this thread, since I am not able to delete it.
    Thanks--Mike
    Nov 2012
    1267
    If you think the problem is on the hardware side, look for an RS-232 driver (or driver/receiver) chip. In the equipment of that vintage, it could be something like MC1488 (also known as SN75188).
    Aug 2009
    1570
    ...So much for the easy fix if all the Parameters are set correctly. Looks like the RS232 chip is on the main board. Here is link to someone with VF-3 that might be what you are looking for.
    Old HAAS VF-3 Serial Port Repair – JimK3038
    DJ
    Aug 2009
    1570
    Quote Originally Posted by CitizenOfDreams View Post
    maybe its the Dallas module causing the drain or battery side of things..from my research 10years unpower was max life.
    Nov 2012
    1267
    I think the corruption of CMOS data would cause many more problems, not just loss of RS-232 communication. But yes, the battery does need to be checked if it hasn't been replaced within the last few years.
    Aug 2009
    1570
    SOS ...---...
  1. Problem with warp function on mk2/9 board
    By AndreaRoss in forum PlanetCNC
    Last Post: 07-05-2017, 11:37 AM
  2. Replacing BMU board in AMADA PEGA 357 (Instaling TULIP Fanram Board)
    By Spanish in forum Maintenance DIY Discussion
    Last Post: 11-21-2015, 02:58 PM
  3. Replies: 0
    Last Post: 11-30-2014, 05:16 AM
  4. G7-Function
    By unchained in forum HEIDENHAIN -> MillPlus
    Last Post: 08-11-2011, 12:49 PM
  5. what is the G52 function
    By glovebox20 in forum Haas Mills
    Last Post: 04-25-2008, 04:07 AM
