CNC milling can cut a range of different materials most commonly including wood, plastic, glass, and metal. Even materials as soft as foam can be cut, if that is what you require. The requirements for the final product will generally determine what type of material you will use. For example, steel provides very strong results, while plastics are perhaps not as strong, but are less likely to corrode.
https://xmncraft.com/using-cnc-milli...ction-molding/
