585,582 active members*
3,731 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > High Density Urethane Foam (A.K.A. Butter-board)
    Jan 2007
    24
    I need to know some good suppliers of high density urethane foam that I can use for making mock up parts and models I've designed in CAD. Does anyone know where's a good place to get some for a good price?
    Apr 2003
    97
    HDU is a staple product for signshops. We use it instead of wood for sandblasted and routed signs.
    Chances are you have at least two sign shop suppliers that deliver to your local area weekly. Do a search in your online yellow pages - and make sure you are looking in a large enough area - my supplier delivers twice a week and is a 2 hr drive - they roam!
    They will be selling it under trade names like Design Board, Sign Foam, Dura Board - etc. Also ask them if they can recommend a sandblaster - they will have a ton of scrap they will sell cheap! Use Gorilla glue to mock up larger pieces as needed.
    Idea of prices.
    4x8 Sheets - 3/4" $157., 1" $196., 2" $326., 3" $500.
    Another note - I prefer using PVC sheets sold under the name brand komatex, sintra - It takes less damage, keeps sharper corners and is flexible enough that we use the 3/4 for 1-off molds.
    4x8 Sheets - 1/8" $25., 1/4" $47., 1/2" $99, 3/4" 125 - much cheaper and more usefull
    Worry about success, failure takes care of itself.
    Sep 2010
    Craft Board HDU
    24" x 48" x 1.5" Craft Board HDU $148.50
    http://www.duracaps.com/product_info...roducts_id/134
  1. Where to buy high density foam?
    By WarrenW in forum Material Machining Solutions
    Last Post: 03-08-2013, 04:04 PM
  2. High Speed CMS FOAM 5-axis milling machine
    By fairlane77089 in forum Hard / High Speed Machining
    Last Post: 06-05-2006, 04:09 PM
  3. Urethane Resin Casting: Linear Glides & Leadscrew Nuts
    By scratch_6057 in forum DIY CNC Router Table Machines
    Last Post: 03-26-2006, 08:13 PM
  4. high-density polyethylene
    By MBG in forum MetalWork Discussion
    Last Post: 09-13-2005, 01:31 PM
  5. High amp driver board
    By jimglass in forum CNC Machine Related Electronics
    Last Post: 04-10-2003, 02:46 AM
