586,009 active members*
4,880 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Mori Seiki SL-1 Lathe Screen Not Turning On
    Jun 2017
    10
    Dear all,
    When I turn on with the green button, the machine turns on half of it (some pcb turn on and some doesnt)
    The Spindle drive does not turns ON. The screen doesnt turns ON.
    I have meassured the 24VDC input in the screen and it is OK (voltaje is present).
    I would like some orientation on where or what to search in the screen pcb.
    It is a CRT fanuc model A61L-0001-0072.
    I am not sure if there must be another input voltage comming from the signal cable.
    I would also apreciate if you can give me an schematic (Electrical) of the screen or the complete machine.
    This is a machine with FANUC SYSTEM 6T
    Thank you for your help.
    Dec 2006
    16
    Re: Mori Seiki SL-1 Lathe Screen Not Turning On
    Martin, Have you been able to repair the problem yet? I had a similar problem a few years ago, and I am going to look for my records on it. Al I remember so far is that there was a board behind the keyboard which has a DC - DC regulator, I believe that it had 24VDC input and 5VDC output, and it was defective.
    Holland Industrial Control Service
    [email protected]
  1. Replies: 0
    Last Post: 11-16-2017, 12:12 AM
  2. Mori Seiki TL-1 CNC Lathe turning center 1982
    By LexLuthier in forum For Sale Only
    Last Post: 06-20-2017, 09:02 PM
  3. Turning question: I.D. ACME thread in Mori Seiki CNC lathe
    By AMCjeepCJ in forum MetalWork Discussion
    Last Post: 03-06-2016, 06:35 PM
  4. Replies: 17
    Last Post: 06-30-2011, 04:36 PM
  5. Replies: 0
    Last Post: 07-29-2009, 11:23 AM
