585,981 active members*
4,074 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Compound mitre joints on a CNC. Help
Results 1 to 5 of 5
    Nov 2019
    15
    Hello all,
    I want to make a 4 sided pyramid out of plywood (I attached a picture to illustrate). The pyramid in the screen shot is just there to demonstrate the shape, its the sides layed out that i want to mill, I also attached a picture of the CAM hoping that better explains. I'm hoping i will be able to construct the pyramid using the panels, im essentially "hoping" to use the my cnc to cut compound mitre joints.
    Wondering if anyone had any input on the best strategy for achieving this, I had an attempt and it didn't work well i got a fair amount of smoke before aborting ...ha, I tried using a 2 flute 6mm ball nose endmill.
    I ran 1600 Rpm
    2500 mm/min feed
    1mm Depth of cut (about 15 passes)
    Im also aware i may be asking to much from a cnc mill and may need to make this on my table saw but given the joints dont have to be perfect i thought i would try it, even if there is a bit of sanding evolved so the edges join nicely it would still advantageous
    Thanks for reading hoping someone might steer me in the right direction
    Dec 2003
    1224
    Re: Compound mitre joints on a CNC. Help
    No picture showing.It isn't that difficult a task with the right software.Model the pyramid with the correct panel thickness,separate the individual panels with the joint surfaces and generate the program to cut them.You will need a packer beneath the panels when they are being machined or the ball end mill will be cutting some grooves in your table.You may need to machine joint faces one at a time if you need to leave clamping arrangements in place.
    Nov 2019
    15
    I not sure why my attached picture never show up
    35538
    Is that 1600 rpm, or 16,000?
    1600 is not going to work.
    Nov 2019
    15
    16,000 sorry typo
