Hi All, I am milling parts from .250" alum plate. The pieces are spacers of a sort. SO they have inside cutout pieces, and then a whole perimeter outside cut out. I am using a .250 end mills. At present I am using tabs to hold all the pieces together then breaking and filing each part after machining. But its time consuming. In the past, I;ve had parts get jammed on the endmill and breakage ensues. Just wondering if there's tricks to not using tabs on everything? My center cutouts are about 1" to 2" varying. If I space stock up above the table and let pieced fall down, would that be viable? I'll try to attach a pic later if I can
