585,996 active members*
3,901 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > LaserCut > LaserCut 6.1 Issue- Whem using the 'engrave' mode the laser does not fire
    Aug 2020
    Hello,
    This is a new issue. I have been converting hand drawn images into .dxf files and importing them into lasercut. I am attempting to engrave the shape rather than cut the outline. The software downloads the file to the machine no problem, but when it starts cutting, the bead moves but the laser does not fire. The laser does perform standard cuts no problem, however.
    I don't know why this is.
    Attached is the .dxf if anyone can tell me why it might be problematic. Or suggest alternative methods of engraving this image.
    Thanks!
    Nov 2010
    15
    Re: LaserCut 6.1 Issue- Whem using the 'engrave' mode the laser does not fire
    I tried importing your attachment to corel and only the red box imported. Have you tried saving the drawing as an AI instead of a dxf? That is all I can suggest with out being able to load it myself. You might want to make sure the lines you want to raster are not set to cut.
  1. F-engrave v1.59 issue
    By thunterman in forum OpenSource Software
    Last Post: 10-29-2016, 05:57 PM
  2. Can't cut/engrave out of Corel/Autocad with LaserCut 5.3
    By rrvrr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-08-2015, 02:59 AM
  3. Lasercut :- Engrave vs GradeEngrave
    By KPBadger in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-06-2009, 09:51 AM
  4. "Fill circle" engrave function LaserCut 5.1
    By grzegorz1965 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-03-2008, 01:04 AM
