585,967 active members*
4,116 visitors online*
    Aug 2020
    5
    Y axis no movement
    I have not had any movement in my Y axis. After a diagnostic check I discovered that it is my driver. I took the driver apart but only noticed some dirt no fuse to be blown . Capacitors and everything looks good to the eye but there is not connection on my A- with solder like the others are connected. Could this possibly be my problem or are they not supposed to be connected? I am pretty new to this so there's no stupid questions right.
    Aug 2020
    Re: Y axis no movement
    Are you saying there is no solder at all on the A- pin? If so, that sounds like an issue. Can you post a picture maybe?
  1. 3 Axis CNC Mill Software for PC - Checking Axis Movement
    By rickwoz in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-05-2015, 04:06 AM
  2. uncommanded A axis movement when doing 4 axis work.
    By Tristar500 in forum Mach Mill
    Last Post: 09-12-2014, 02:47 AM
  3. X axis differential to create Y axis movement.
    By mpatterson557 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2014, 12:18 AM
  4. Grinding and unexpected axis movement if rapiding 2 axis
    By DarkSabre in forum Taig Mills / Lathes
    Last Post: 03-26-2010, 05:37 AM
  5. Axis Movement
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 12-17-2004, 08:33 PM
