585,753 active members*
3,645 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > After 2 month covid shutdown - 21T wont boot - 4 simultaneous screens of garbage
Results 1 to 8 of 8
    Dec 2018
    25
    Hi
    machines were shutoff for a covid shutdown, for 2 mos, just tried booting up the 21T. Machine was happily shut down as normal, battery was in good shape (just replaced) prior to shutdown.
    After "on"... no pumps coming on, no servos coming on. Screen comes up with what looks like 4 "subcreens" (this is a monochrome monitor, so it def doesnt have the resoloution for 4 screens LoL), looks like top left is same as top right is same as bottom left is same as bottom right - but mirrored 4 times - cant make out the words - as if it was low res.
    Looked in the back there is no error just two red bars "- -" which I understand to mean "not ready"...
    anyone any ideas ?? in a bit of a jam...
    THanks
    Dec 2018
    25
    Re: After proper shutdown - 21T wont boot - 4 simultaneous screens of garbage
    Here is a shot of the screen:
    Aug 2009
    1570
    Re: After 2 month covid shutdown - 21T wont boot - 4 simultaneous screens of garbage
    ...the virus continues
    Try leaving it powered up for a while....reboot
    Dec 2018
    25
    u mean like leave the mains on.. like to warm it up ? then just hit off and then on again on the control ? this is scary was thinking powered up mught be frying ****.. or do u nean turn off mains to reboot.. has this been seen before ?? im stumped
    Do you have a control backup? Do you know how to get to the BOOT screen?
    May 2016
    526
    check your 24v to the board
    Dec 2018
    25
    I dont think I have a control backup, I have the parameters, but no card. BOOT screen, no not sure. I will check the 24v..
    May 2016
    526
    Whereabouts are you as there maybe an engineer local to you on here
  1. LB15 wont boot up need help
    By rotec in forum Okuma
    Last Post: 12-17-2012, 06:32 PM
  2. 2006 TM1 wont boot up.
    By sexton in forum Haas Mills
    Last Post: 07-01-2012, 01:59 PM
  3. Won't boot up, Garbage on the screen
    By ddgman2001 in forum Fadal
    Last Post: 05-12-2011, 11:20 PM
  4. 2001 VF1 Wont boot up!
    By CAN MACHINE in forum Haas Mills
    Last Post: 03-21-2011, 04:15 PM
  5. VF4 WONT BOOT
    By jimzin15754 in forum Haas Mills
    Last Post: 06-03-2008, 11:23 PM
