585,702 active members*
4,185 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > possible tools for measuring z-axis repeatability?
Results 1 to 9 of 9
    May 2018
    52
    Other than a two dial tramming tool, what other tool or tools might be used to measure z-axis repeatability? I don't currently have a tramming tool, so I tried using a digital weight scale, which would work fine if repeatability were perfect, but otherwise it's hard to know how to convert grams into distance.
    I thought about using a dial indicator, but where to attach it?
    Then I thought about using a dial test indicator. Maybe?
    What else might be used?
    Dec 2013
    5717
    Re: possible tools for measuring z-axis repeatability?
    I guess I would use a dial indicator and attach it to the spindle by any reasonable method.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2015
    4154
    hy white traming and repetability are different things
    for repetability, use a code with low feed ( circa 0.01mm / 5 seconds ), exact stop, and uni-directional positioning + attached / kindly
    May 2018
    52
    Quote Originally Posted by deadlykitten View Post
    Easier said than done. How exactly do I clamp it from the back, and to what do I clamp it?
    Dec 2003
    1216
    I use a piece of silver steel in the collet and attach the dial gauge to that.Once satisfied with the repeatability you can then attach an arm to the silver steel and move the dial gauge onto it for tramming purposes.I have known a man who had a steel rod bent to a ninety degree angle and which he used with the correct collet for tramming, you do need to be careful about making small adjustments.For information,I have had a variation of less than 0.001" on a five inch rod over a 360 degree rotation with a melamine faced chipboard piece as the table face.
    Jun 2015
    4154
    hello again i use attached : is a powerfull magnetic base ( bigger&stronger than usual ), with simple&rigid clamp ( so to avoid useles articulations and fancy-but-precision-loss-clamps ) and fine base adjustement ( so to be able to adjust the position without moving the dial in reverse direction after the hand lifts off; this fine adjustement speeds up the setting duration, making it fast to hand-dial at zero, or at any other value that you wish )
    is not hydraulic, but mechanical - tough; if it matters, it's a noga
    this so called " setup " is pretty accurate, and i don't use it for rough measurements, but only for finess
    to achieve measurement consistency, especially at these 1um scale, don't move the ' object ' on a direction that is perpendicular to the dial ( so to avoid palpator 'micro' tilting ), but only across paralel directions ( or close to being paralel; it's that so called precision-cone ) ; for example :
    ... to measure Z positioning, put it upside down ( i reffer to this position as ||vertical or ||z, thus the dial is paralel to a vertical axis, or to the z axis; is the same thing for a vmc, unless the machine is tilted, like those boat-shops travelling in international waters, so to avoid taxes )
    ... for traming, don't rotate it on the table, but only raise it and lower it at different spindle phases ( but is better to tram with a less precise dial, and only use this high-precision dial for final control; being so accurate, it is suitable for fine control, like quality gauges inspection, tool tir, axis positioning, but not for machining geometry, or at least not for general purpose machining geometry ... it is beyond that, it is suitable for grinding-like precision stuff) / kindly
    ps : sorry if this is too much info, i realized just now that this is a thread for wood routers/chinese machinese ... hmm; i guess is ok
    ps2: thanks to the one that clicked reputation on previous post
    Feb 2023
    3
    Talking about measuring z-axis repeatability can be quite the puzzle, but don't worry, we've got options!
    Jul 2023
    Using a digital weight scale is a neat idea, but I get what you mean about converting grams into distance—it can be tricky to get precise measurements that way.
    A dial indicator could work wonders! You just need to figure out where to attach it securely for accurate readings. And hey, a dial test indicator might be another fantastic option! It's all about finding what fits best for your setup.
    Jul 2023
    Quote Originally Posted by darkwood View Post
    BTW, have you ever considered a virtual ruler? There might be some cool digital solutions out there that can help you measure z-axis repeatability without the need for physical tools. Keep exploring and experimenting, and you'll find the perfect solution for your needs!
  1. Measuring of stamping tools
    By peter1980 in forum Chucking and Measuring
    Last Post: 11-21-2019, 09:17 PM
  2. Replies: 13
    Last Post: 08-01-2018, 06:10 PM
  3. Measuring absolute position and repeatability of rotating axis
    By PCTMachining in forum Maintenance DIY Discussion
    Last Post: 09-12-2017, 01:04 PM
  4. help finding some new measuring tools
    By Teyber12 in forum Uncategorised MetalWorking Machines
    Last Post: 01-20-2010, 07:19 PM
  5. Asimeto measuring tools?
    By Chuck Reamer in forum Calibration / Measurement
    Last Post: 02-15-2008, 03:26 PM
