585,981 active members*
4,087 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > 110v to220v step up transformer for US 220v cnc router?
Results 1 to 12 of 12
    Jul 2017
    348
    I have a cnc router thats requires 220v single phase for its power box....power box has a 220v output for the 220v 2A router and a 110v output for the controller
    i was told by the transformer manuf that transformers will not work with US 220v products...only will work on foreign 220v products.
    is this true or just Liability BS
    15362
    Re: 110v to220v step up transformer for US 220v cnc router?
    Quote Originally Posted by Shelby5041 View Post
    Partly correct but NA 240v single phase output is no different where ever you live, there is some different configurations of the wiring but that is all
    The Transformers would need to be sized correct and it's wiring is different from USA wiring it will have ( 1 ) Hot live and Neutral Ground, US supply you have ( 2 ) Hot Live wires and a Ground both are equal and do the same job
    You can buy these Transformers you are talking about on Amazon and a lot of Hobby guys us them
    Mactec54
    24221
    Do you have a link to the product in question?
    Al.
    Albert E.
    Jul 2017
    348
    ok thanks
    no link..just typical 110v-220v step up transformer they sell all over the internet 3000w version
    ebay amzon aliexpress..everywhere
    all the same
    Sep 2005
    1195
    I have transformer step up/down ... 1 neutral, 1 live, 1 ground (body) ... I think all the same ... I have step down made in Indonesia to use with my kitchen aid, no problema ... toroid or steel block ... I have used both ...
    Aug 2009
    1573
    ..thats all total BS. https://circuitglobe.com/difference-...ansformer.html
    24221
    ok thanks
    I would wager that most of those are SMPS, not a typical linear version.
    Al.
    Albert E.
    Sep 2005
    1195
    Sorry, I mean all step up is the same in usage ... all step down is the same in usage ...
    Jul 2017
    348
    Ok here is what i have...will this power a 220v 5a router
    According to manuf of transformer it will not work with any usa 220v products.
    - - - Updated - - -
    https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F29 3272782936
    15362
    Al.
    All of these I have seen are linear have not seen any SMPS, typically just a Transformer circuit breaker Etc
    Mactec54
    15362
    - - - Updated - - -
    https://rover.ebay.com/rover/0/0/0?m...2F293272782936
    I doubt that 5A will be enough for your whole machine you need the total Amps for your machine, is it using a VFD Drive for the spindle motor then if the spindle motor is 5A then you need double that plus a safety factor normally the average small machine need a minimum of a 20A supply
    Your link is incorrect
    Mactec54
    24221
    Appears to be a bum link.
    Maybe the Manuf comment/concern was due to the products system earth ground being re-referenced to one side of the 220v secondary, which is normal.
    But even if this was the reason, it should not normally matter in a N.A. 220v device.
    If the OEM is in China then may be take this with a grain of salt!
    An internal inspection would confirm.
    Al.
    Albert E.
  1. Replies: 21
    Last Post: 04-18-2020, 01:37 AM
  2. 220V spindle on 110V?
    By rs4race in forum Spindles / VFD
    Last Post: 09-10-2018, 05:05 PM
  3. 110v vs 220v 1.5KW Spindle
    By kingofl337 in forum Spindles / VFD
    Last Post: 04-26-2018, 11:15 PM
  4. Replies: 2
    Last Post: 11-06-2016, 03:01 AM
  5. K40 220V to 110V conversion, how?
    By 18111 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-12-2013, 09:24 AM
