585,668 active members*
3,895 visitors online*
Results 1 to 5 of 5
    Kit vs 100% DIY cost difference
    Greetings all. I am insanely busy at the moment, but I need to lay out a basic financial plan for this fall and for that I need to get a decent idea of how much money I need to allow for this tool.
    I need a 4' x 8' CNC Router table for cutting MDF up to 3/4, plastics up to 1/4, and possibly aluminum sheet metal. Accuracy of 1/16" should be more than good enough for my work.
    I'm looking at the "CNC Router Parts" kit, but it's a bit more expensive than I was hoping I could get away with.
    So, how much money would I need to allow for building 100% DIY using one of the sets of plans from this forum vs. buying a kit like the one from CNC Router Parts? I'm just looking for a decent ballpark figure so I know what to put in my budget for this.
    Thanks!
    35538
    Re: Kit vs 100% DIY cost difference
    Probably save around 30%, but plan on spending roughly 300 hours for sourcing, design, and assembly.
    Price can vary considerably depending on the components you choose.
    Their Plug and Play spindle package is $1700, but you can buy a cheap Chinese spindle and VFD for about $350. VFD cable will cost about $100, but your saving 70%
    Jan 2008
    1527
    If you are insanely busy you don't have time to DIY.
    If the process of designing and building a CNC machine is enjoyable to you that is factor. It is for me. I'm slowly designing a decent size metal mill. I don't know what I'll make with it. That's not the point for me, CNC is my hobby.
    If you just want a CNC working and making parts buy the Avid (previously CNC Router Parts) kit
    Jan 2016
    69
    Don't DIY, That is a job (or hobby) in, and of, itself. Just buy the Avid Prop kit and assemble it. You will save money in the end.
    May 2004
    210
    There are different levels of DIY. I'm in the process or getting a "large" CNC router so am a bit ahead of you in the process. I've pretty much settled on the Avid PRO4848. I see 3 distinct and separable pieces - mechanical assembly (rails, frame, ...), electronics/motors and spindle. Avid will supply all or part of those. For me, doing the mechanical part is a huge time sink with far too many degrees of freedom for even a skilled hobbyist. I will just buy that from Avid. I agree with the Chinese spindle advice. For the Avid price you can buy at least 3 ebay/amazon Chinese spindles/VFDs (4 if you shop around). The plug and play electronics kit is in the middle - if you have an understanding of the electronics and stepper motors needed, it's quite doable. I will be building my own and will probably save about 40% off the Avid price. If electronics is a complete mystery to you - buy the package.
    By the way, be sure to cost out tooling and other incidentals, they add up pretty quickly. I have a lot more invested in router bits than I ever thought possible.
  1. Difference between VM3 & VF3?
    By behindpropeller in forum Haas Mills
    Last Post: 03-22-2012, 06:17 PM
  2. Difference between
    By CHANDRU in forum Linear and Rotary Motion
    Last Post: 02-17-2009, 01:31 PM
  3. What's the difference?
    By ignatz in forum Stepper Motors / Drives
    Last Post: 03-08-2006, 05:39 AM
