I have an Issue with my Wabeco F1210 ich is controlled by a Mach3 USB-Board.
I just bought an Springloaded Drag Engraver 2 weeks ago and I have an weired issue, which im unable to solve or even know where to look at, since than.
If the machine engraves outlines of the letter "E" in Arial the top horizontel Line is thiner than the other ones, same for letter F.
I do have the same issue, when I rotate the text 90 degrees.
The letter "L" is engravet with a thin vertical line. Rotated 90 degrees the horizontel line gets thiner.
Now comes the confusing part.
The letter "Z" is displayed right everytime.
If I rotate the whole Text 45 degrees the failure doesnt appear at all.All letters a properly engraved.
So my guess is,something with my Mach3 configuration is wrong.
( I tried estlcam, f-engrave,and corel+gcode encoder with the same results)
Does someone know what im doing wrong?
