585,753 active members*
4,451 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Slitting 4140 - Work hardened - How to recover
    Mar 2007
    12
    Hello;
    I'm having trouble slitting 4140. Being a novice, I overheated the cutter by running to fast an rpm and the slot has work hardened. Hack saw skates in slot, rear of slot is discolored. I suspect I need to anneal the piece to get past this but am concerned it might damage the part..
    Any suggestions on how to complete the slot?
    Details:
    Hand milling on RongFu Mill - traditional hand fed - not climb milling
    Slot 1/6" wide 3/8" deep, 5/16" long in 4140 (Initially non hardened)
    Have about .100" left to cut
    Saw was HSS 3" x 1/6 x 1" arbor no key, 30 teeth - flat tooth, on a china universal size arbor.
    Even though was to fast, It cut fine .020 per pass with a little machine oil coolant till I got to the tooth depth. Started to make some awful noise...etc.
    My current plan is to pickup a few saw blades with key, try to cut through at a very slow feed with an alternate keyed arbor which I have somewhere. If that fails anneal and use one of the spare saws.
    Any suggestions on blades, speeds, etc to complete cut would be greatly appreciated.
    Mike
    Mar 2007
    12
    Re: Slitting 4140 - Work hardened - How to recover
    Well I was able to finish the slot by hand with a diamond needle file. It appears suitable for now.
    The best suggestion I've found for the saw is 70rpm with a warning for feed calcs that not all teeth are engaged with these saws
    Sorry if I posted in the wrong Forum
    Mike
  1. I can not recover kflop.
    By mk00 in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-20-2019, 08:01 AM
  2. need help recover tool changer.
    By 77volvo245 in forum Bridgeport / Hardinge Mills
    Last Post: 11-10-2012, 07:16 AM
  3. TOOL RECOVER PROBLEM
    By razzz in forum Haas Mills
    Last Post: 01-25-2012, 02:44 AM
  4. RECOVER PROGRAM
    By JERRYPEREZ in forum Haas Mills
    Last Post: 07-19-2010, 06:04 PM
