585,758 active members*
4,435 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > How to run engraving program at different depth
    Feb 2017
    I am running a 600 line engraving program on a Haas, need to run again at a different depth. Have been changing tool length comp, but loosing too much time.
    Sep 2018
    27
    re: How to run engraving program at different depth
    Add G92 Z-10 (Or Z-Whatever you need)
    It should shift the Z coordinates and run all the nc accordingly
    Make sure however that all your rapid moves are still above material, or at least inside the pocket you already performed.
    Feb 2017
    Re: How to run engraving program at different depth
    Thanks Lucas for taking time to help. Will try it today.
  1. Engraving help? Which tool for this depth?
    By darrenk in forum CNC Tooling
    Last Post: 12-01-2018, 04:59 PM
  2. Engraving Depth Regulator Attachment
    By big-div in forum Avid CNC
    Last Post: 03-23-2015, 02:02 PM
  3. Engraving bits and depth of cut
    By map84 in forum CNC Tooling
    Last Post: 03-06-2014, 01:29 PM
  4. Problem engraving - depth changes
    By dminnery in forum Vectric
    Last Post: 08-08-2013, 01:33 PM
