584,837 active members*
4,895 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 16 changing X axis sign in G53 from minus to plus
Results 1 to 3 of 3
    Jul 2014
    221
    Hello, is there a parameter or option for changing value of machine coordinate system direction, from minus to plus so when i end program by writing
    G53 Z0.
    G53 X200. Y0.
    I wouldnt get an error regarding OT alarm?
    Because normaly i would have to end it writing
    G53 Z0.
    G53 X-200. Y0.
    Dec 2008
    3110
    Re: Fanuc 16 changing X axis sign in G53 from minus to plus
    G53 is the machine co-ord system
    ... G53X0Y0Z0 is also the "homed" machine position
    Any values placed in this line are relative to this home position. There is NO relationship to the work co-ord system(G54-59 etc) if G53 is used
    If home is back-left table corner... then any X value must be +ive
    If home is back-right table corner... then any X value must be -ive
    Which corner is your home ?
    Jul 2014
    221
    Quote Originally Posted by Superman View Post
    That is all correct but on Haas mills there is an option for selecting x axis direction for g53 pos or neg)so i thought there might be on fanuc also
  1. Fanuc 21T No sign of Life!
    By GC1 in forum Fanuc
    Last Post: 03-20-2019, 09:13 PM
  2. V3 post for FANUC 10 has the wrong sign on K numbers
    By CNCturtle in forum BobCad Post Processors
    Last Post: 10-17-2014, 12:24 AM
  3. axis goes plus or minus on it's own
    By glentner in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-28-2013, 03:45 AM
  4. Fanuc 0M - Changing Axis Limits
    By MotoDan in forum Fanuc
    Last Post: 07-24-2010, 01:28 AM
  5. Y axis moves minus but not plus
    By daedalus0x1a4 in forum Bridgeport / Hardinge Mills
    Last Post: 05-04-2009, 05:00 PM
