585,729 active members*
4,862 visitors online*
    Sep 2017
    33
    Acrylic and metal Adhesive?
    I have cut out some stars and moon shapes out of Acrylic and want to glue in some metal rivets/studs into cut holes.
    The Rivets are almost a snug fit but move from side to side a little. What adhesive should I use to keep them in place? I hear super glue isn't ideal due to melting the Acrylic.
    Thank you for any advice,
    Jan 2008
    940
    Re: Acrylic and metal Adhesive?
    Have you thought about just using a rivet tool to snug up the rivets and not break the pins off.
    Sep 2017
    33
    Quote Originally Posted by fixtureman1 View Post
    Thanks for reply.
    No, they have to drop on. They are not proper rivets. Just screws that have a rivet like head.
    Jul 2018
    6319
    Hi WW10 - superglue will craze the acrylic. Epoxy will work. Peter
    Nov 2007
    2151
    In my experience If it is "acrylic" cell or cast almost nothing will bond to acrylic but acrylic "long term". In general it takes a product like weld on 3, 4, ..... to chemically melt the material together and form a bond.
    You can use an epoxy that is formulated for acrylic to bond something non acrylic to acrylic but this will not hold long term or very well. imho
    Best method would be to cast embed into the sheet. Or better yet no holes at all and capture frame the material to hold in place.
  1. Blue Elephant 1325 4 axis wood carving router for wood acrylic metal
    By BlueElephantCNC in forum News Announcements
    Last Post: 11-18-2019, 10:25 AM
  2. Replies: 1
    Last Post: 05-14-2012, 12:43 PM
  3. Aluminum adhesive help!
    By DrStein99 in forum MetalWork Discussion
    Last Post: 11-17-2005, 06:31 AM
