585,692 active members*
3,974 visitors online*
Results 1 to 3 of 3
    Dec 2019
    Tnc 355 drip feed
    Hello,
    I would like to transfer long programs to my TNC 355 (<1000 lines).
    At the moment I can already transfer small programs (with TNCServ and RS-232 interface).
    I've already spent some time trying to find a solution, but I don't really know where to go.
    Does anyone know which parameters to change? Is it possible to use the TNCServ?
    Thank you in advance!
    Aug 2009
    1570
    Re: Tnc 355 drip feed
    Dec 2019
    Thanks for the help!
    After a day of research and testing, I think I've found the solution.
    For people who have the same problem, here is the configuration I used and that seems to work:
    On TNCServ:
    Protocol: FE
    Serial port: depends on your pc
    Baud rate: 9600
    On the TNC 355 :
    Protocol: FE
    Baud rate: 9600
    MP 218: 17736
    MP 219: 16712
    MP 220: 279
    MP 221: 5382
    MP 222: 168
    MP 224: 4
    To load the program : -> "step mode key" or "continuous mode key" -> EXT-key -> type the program name -> the program will load -> GOTO-key to navigate through the lines.
  1. IMA 210 CNC Drip Feed
    By 9thraven in forum CNC Machining Centers
    Last Post: 03-12-2024, 09:18 PM
  2. DNC/Drip Feed
    By rsfairman in forum Fanuc
    Last Post: 03-06-2015, 11:24 PM
  3. drip feed
    By kirby in forum Fanuc
    Last Post: 11-29-2009, 03:04 AM
  4. Drip feed?
    By MrWild in forum Dolphin CAD/CAM
    Last Post: 02-25-2008, 05:33 AM
  5. Drip Feed
    By camtd in forum Surfcam
    Last Post: 08-01-2006, 12:09 AM
