584,862 active members*
5,363 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Adjusting backlash on a VK 45 II
    Hello,
    How do I adjust the backlash on VK 45 2 with seicos M3 controller? I noticed that the Y axis has 0.06 mm backlash. The manuals I have don't show the procedure or how to interpret the mechanical compensation parameters.
    Dec 2009
    539
    Re: Adjusting backlash on a VK 45 II
    Quote Originally Posted by viorel23cnc View Post
    Hello,
    Hello!
    It’s parameter 1833 for the backlash compensation on a Seicos MIII, goes in order of x,y,z
    John
    Jun 2022
    Quote Originally Posted by shas595 View Post
    Hello!
    John
    Please can you describe the procedure?
    Mar 2009
    1982
    did you check if it's possible to eliminate mechanically ?
    Jun 2022
    Quote Originally Posted by Algirdas View Post
    Yes but I have only 0,015mm and for this I think that the software corrections it's okay
  1. Adjusting preload/backlash in these screw support bearings?
    By jevs in forum Uncategorised MetalWorking Machines
    Last Post: 02-28-2014, 02:03 AM
  2. Adjusting Y axis backlash Boss 6.1
    By creep_pea in forum Bridgeport / Hardinge Mills
    Last Post: 08-23-2008, 07:31 PM
  3. Adjusting Backlash Compensation on a Cen. 6
    By TZ250 in forum Milltronics
    Last Post: 11-10-2007, 03:31 AM
  4. Adjusting crossfeed backlash on Busy Bee
    By chardinej in forum Mini Lathe
    Last Post: 08-30-2007, 03:15 AM
  5. Adjusting backlash on VF-OE
    By eddie in forum Haas Mills
    Last Post: 12-22-2004, 09:20 AM
