585,902 active members*
4,150 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Limit Switch in DSP0501 - Can I use a simple NO switch as limit switch
    Aug 2020
    12
    I am converting an old Berco Surface grinder / milling machine to CNC using DSP 0501 and Gecko 201. I need to and I like to have limit switches on the 2 axis but I see the wiring diagram in the manual shows NPN limit switches.
    Is it possible to use NO or NC mechanical switches for this?
    I have attached the relevant page of the manual
    TIA
    Tom
    Nov 2012
    1267
    Re: Limit Switch in DSP0501 - Can I use a simple NO switch as limit switch
    Quote Originally Posted by silver_fx View Post
    Yes, absolutely. NPN NO switch can be directly replaced with a mechanical NO switch. Connect the switch to the BLUE and the BLACK wire.
    P. S. Why not use proper inductive switches? They are fun to work with, they have built-in indicator lights for troubleshooting, and they cost peanuts nowadays.
    Aug 2020
    12
    Thanks vm. Well I will be but I have none yet, just order them but I thought in the mean time I can try the mechanical ones which I have e few.
  1. MACH 3, Warp9 smooth stepper, Leadshine mx4660 Limit switch home switch woes HELP
    By cabinman in forum Mach Software (ArtSoft software)
    Last Post: 01-14-2018, 08:26 PM
  2. Limit switch replacement with proximity switch?
    By Normsthename in forum Bending, Forging, Extrusion...
    Last Post: 07-11-2009, 04:38 PM
  3. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
