Hi P2N - A solution for your issue of connecting things square is to use the brackets that companies like 80/20 supply. They are cheap and square. If you use these you can get square stiff joints in plywood or sheet metal or plate machines. Use the ones with webs they are much stiffer then the simple L type ones. Time to see a sketch of your machine? Peter
