585,992 active members*
5,238 visitors online*
Thread: dxf to gcode
Page 1 of 2 12
Results 1 to 20 of 23
    May 2008
    12
    dxf to gcode
    I made a small application to convert dxf to gcode and i like to ask if here is the right place to submit it and get some feedback from the users.
    Thank you.
    35538
    Sure.
    May 2008
    12
    Here is my small application.
    DXF in Fire
    This application will open most of the DXF types and convert them to gCode.
    Supports 2D dxf and layers
    If your DXF has layers then you can select the layer and export it in gCode.
    Any improvements you may think i would like to here them and I will add them to my 'Todo' list.
    I will try to add more features in the next version
    There is not any help file for the moment but i think is very simple to use it.
    Please feel free to download it and if you can give me your feedback i will appreciate it.
    Finally I'm sorry for any bugs you may find in this early version.
    Thank you
    Apr 2005
    3634
    LOL
    How do you download the .zip?
    I can't find a link (on rapidshare).
    Free DXF - vectorink.com
    Jun 2008
    128
    With Rapidshare click on "free user" button and you will have to wait 30 seconds for download button to appear
    George
    Apr 2005
    3634
    I downloaded your program.
    1) I don't see anything, as far as tool setup, depth of cut, etc...
    2) No header in g-code
    3) No feed in the g-code (F)
    4) No M30 at the end of the g-code
    5) Also, when you go to save the g-code, the .dxf extension is the only one that will save, no big deal to rename as a .txt file manually, just thought I would mention that.
    Not complaining, just trying to help.
    May 2008
    12
    Thank you for the fast feedback Switcher.
    Your comments are welcome.
    I will try to fix these and I will post a fixed version.
    Most of your comments can be fixed very easily.
    Jun 2008
    128
    Tried program but it does not include G codes?
    Sample of first few lines - not there is no "G01" in each line just xy values
    N0 Z200
    N1 X179 Y588
    N2 Z-200
    N3 X179 Y588
    N4 X214.231507 Y620.750685
    N5 X294 Y694
    N6 X318 Y718
    N7 X317 Y719
    N8 X125.25 Y718.75
    Also :
    Layers screen loads too high so X at top is hidden by menu so I have to close using menu.
    I sometimes get a subscription out of range error when loadiing file but does not seem to cause a problem.
    George
    May 2008
    12
    Thank you for your comments.
    A new version with all or most of your comments fixed was uploaded while ago.
    Please get the new version and test it.
    I would love to here more comments and requirements in case you have any.
    The new DXF in Fire is here.
    You are all welcome to test it and tell me what you think about.
    May 2008
    12
    a newer version is available to import gcode too.
    Now it will convert dxf<->gcode
    There some issues yet to be solved but this is just for testing and your feedback please.
    Here you can get the new DXF in Fire
    Thank you
    May 2008
    12
    Hi all
    here is an update version.
    DXF in Fire
    news:
    support for lwpolylines added.
    improved/faster conversion .
    support for more dxf versions.
    Please try it and you may give me some feedback to improve it or fix it
    thank you.
    Feb 2010
    Very good work.
    Did you make all the DXF import and drafting yourself?
    Do you know where can i find the source code for import and drafting functions?
    I want to import and draft DXF files with VB for other purpose (my machine does not support G code - i can only work with points file, so i want to convert the dxf to points file).
    Thanks,
    Nir
    Nov 2009
    77
    This is what I've been looking for! I'm very new to cnc so forgive my simple questions. I use Autosketch to make dxf (there are a few different versions of dxf in Autosketch for some reason) and want to generate tool paths.
    It would be very helpful to me, and to others, if you could make a quick video for youtube that shows you setting up the files, running it, looking at the generated files, and then feeding it into a g-code simulator program to make the cuts.
    Very nice work!
    cnc1000
    Jun 2010
    I have a file with extension MPG (ready to be loaded on a CNC plasma cutting machine) and I need to converted to a DXF file
    I would really appreciate if anyone can help me, by advising any free converter
    3
    4
    5
    +0+1196
    6
    30
    7
    +200-200+0-200-
    +0-546
    +250-250+250+0+
    +1100+0
    +250+250+0+250+
    -250+250-250+0+
    -950+0
    +0+230
    -70+70
    -235+0
    48
    -91+0
    -160+160
    8
    38
    -44+736
    30
    7
    +200-200+0-200-
    +0-396
    +1050+0
    +250+250+0+250+
    -250+250-250+0+
    -300+0
    -170-100
    -475+0
    48
    -101+0
    -160+160
    8
    38
    63
    May 2007
    22
    Converter...
    I dont' think there is a MPG to DXF converter. The Format, seems to be proprietary although, being an ascii file, shouldn't be too difficult to write a converter. Which brand your plasma cutter is ? May be that the company that sells it could have a converter.
    Sandro
    Jun 2010
    Thanks Sandro for your reply.
    I don't know the manufacturer of the plasma cutting machine.
    Can you help me on where to find the meaning of the codes used by MPG format?
    Thank you in advance.
    May 2007
    22
    If you don't have documentation of the machine it will be very hard to desume the file format. I'm surprised that you don't know the builder.. There is no builder logo or machine model name on the machine frame ?? The .MPG extension is meaningless if there is not any other reference. If you have A LOT OF TIME to spend.. try this :
    Write a program that cut for example a squared plate of known size (let'ìs say 100 x 100 mm) and examine the output code. You should desume some info like torch on and torch off command.. positioning commands and so on..
    Then pass to more complex geometries like arcs or circles..
    This could work, but it absolutely will take a lot of time and I don't know if it'worth the effort. Keep the forum updated on your researches..
    Sandro
    Sep 2011
    5
    Quote Originally Posted by Megalos View Post
    Thank you.
    Hi Megalos, I'm very interested in your project, and now I'm doing similar work, so maybe I really need your help. can you reupload your application, old links died all, thank you!
    Anyway, how can I contact you to discuss?
    May 2008
    12
    old links are dead and i'm very sorry about that., I will try to upload the files again later today.
    May 2008
    12
    new working links
    just put some files here Index of /CNCproject
    thank you
Page 1 of 2 12
  1. dxf to gcode ??
    By thanhtroa in forum OpenSource Software
    Last Post: 10-23-2009, 04:50 AM
  2. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  3. GCode
    By rogerbureau in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-07-2005, 02:36 PM
  4. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
  5. Gcode to DXF?
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 04-30-2003, 11:40 PM
