585,942 active members*
3,339 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Spindle & VFD Confusion
    Talking Spindle & VFD Confusion
    Hi all,
    At the moment I am as green as grass, lol
    I have just purchased the following spindle and VFD INVERTER Huanyang Brand 2.2KW
    2.2kw spindle motor
    Frequency: 400 Hz
    Voltage: 220V~250V Power: 2.2 KW
    UPC: 283961306057 Speed: 8000-24000 R/min
    EAN: 0283961306057
    I am based in Melbourne Australia. Is there anyone out there from Aus? Has anyone set up this configuration before?
    Not been getting much help from the eBay seller. The spindle I am confident but the VFD Inverter I am a little confused as to the power etc.
    I have told them that the required unit is to be 2.2KW 380V ???
    15362
    Re: Spindle & VFD Confusion
    Quote Originally Posted by markenfield View Post
    Hi all,
    2.2kw spindle motor
    Frequency: 400 Hz
    EAN: 0283961306057
    The VFD drive, you have will run on your 230v/240v Single phase but if you have 400v / 415v 3phase then yes you would want there 380v VFD Drive and spindle both the VFD Drive and the spindle need to be the for the same voltage that you are going / want to use
    Mactec54
  1. mazak sub spindle turning confusion
    By bole in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-21-2016, 10:09 AM
  2. Spindle as stepper setup confusion
    By dafunkdawg in forum Mach Mill
    Last Post: 04-10-2016, 06:26 PM
  3. Replies: 14
    Last Post: 05-23-2013, 07:59 PM
  4. Confusion with R8 Spindle and Collets
    By RPCElectronics in forum Benchtop Machines
    Last Post: 04-19-2011, 07:31 PM
  5. X2 spindle dimension confusion
    By cyclestart in forum Benchtop Machines
    Last Post: 08-25-2008, 02:42 PM
