585,987 active members*
4,316 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi seiki vm40 spindle wont go over 3000rpm
    Hi i hope some one can help. I have a Hitachi seiki vm40 with Seikos control, it has Mitsubishi 6000rpm spindle motor and drive. It will not go above approx 2900rpm. No alarms, no load on spindle, no noises. Control working perfectly otherwise. Can some one give me some helpful advice?
    Thanks in advance,
    Craig.
    Jul 2020
    7
    Re: Hitachi seiki vm40 spindle wont go over 3000rpm
    Do you have a winding's selector? Sounds like you are not getting into the H windings? Also, check the drive parameters? Did this happen all of a sudden?
    Quote Originally Posted by Craig1971 View Post
    Thanks in advance,
    Craig.
    If it is using frequency inverter, then you can check its setting for highest speed, is it match with 6000rpm speed?
    Or you can check the electronic gear ratio setting.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  1. hitachi seiki spindle wont turn on
    By docdesigns in forum Hitachi Seikis
    Last Post: 09-19-2018, 08:59 AM
  2. Hitachi Seiki VM40 seicos 2
    By bevins in forum Hitachi Seikis
    Last Post: 05-08-2013, 04:06 AM
  3. hitachi seiki vm40 error 141
    By Mousie in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-15-2009, 10:10 AM
