Please get helpme to conect the lathe cnc with FANUC SERIES Oi Mate-TB control with my pc
my pc has windos xp home edition and i have a communication program edge cam.
I dont now how to adjust the conection parameters in the cnc.
Thanks a lot.
Thanks a lot.
The 0i set-up is the same as a 16/18/21 controller.
1)Select "MDI" mode
press "setting" button, set I/O Channel = 0 or 1 or 2
2) If you choose "0" channel, then you need setup in
#101 - 10000001 for 2 stop bit
#102 - 0 for XOn/Xoff ( or 4 for none)
#103 - 11 for 9600 bps (or 10 - 4800 bps)
If you choose "1" channel, then you need setup in
#111, #112 and #113
If you choose "2" channel, then you need setup in
#121, #122 and #123.
3) in PC site , you need a commucating program or you create a simple program in Bacic-language.
Good Luck!
