585,992 active members*
5,795 visitors online*
Thread: dsPic-Servo
Page 9 of 9 789
Results 161 to 172 of 172
  1. #161
    Apr 2004
    209
    smarbaga
    Do you have a final release PDF or brd-sch etc.. final files of your layout???? I like yours best, and am planning on building it. Or better yet, pro blanks fab boards??
  2. #162
    Jan 2009
    334
    Iron-Man Servo
  3. #163
    Jan 2007
    93
    Which pins are used for H-bridge in the last hex code yapsc_v1?
  4. #164
    Oct 2010
    is this controller for a BLDC motor or Brashed ?
    i search for a Brushless dc or Ac Motor Contoroller .
  5. #165
    Jan 2007
    93
    Quote Originally Posted by irxplod View Post
    It is for Brashed motors.
  6. #166
    Dec 2009
    8
    Hi, my servo encoder output is A and B do not have a output INDX whether it will work properly with driver version V1?
  7. #167
    Dec 2011
    [ame="http://www.youtube.com/watch?v=6XbgN3uNVdw&feature=endscreen&NR=1"]http://www.youtube.com/watch?v=6XbgN3uNVdw&feature=endscreen&NR=1[/ame]
    dspic30f4011 LCD 16x2 DISPLAY
    encoder 1000 p/r
    lcd Show
    x feedback eencoder
    c command from pc mach3 cnc sof
  8. #168
    Oct 2010
    448
    Re: dsPic-Servo
    As much as I like the idea of open-source hardware/software, I am greatly disappointed in the lack of an inexpensive funcitonal DC servo driver.
    Don't get me wrong, there have been some interesting designs posted and some that appear to have merit (roverto_c's Schema.zip needs minor mods like schottky diodes diodes) but all seem to be incomplete, some missing source code, others have strange power supply requirements (OPA549).
    Those who have offered such designs like Iron-Man and Max-Mod have all vanished making obtaining a reliable working design impossible.
    I'd really like to find a working solution that targets the electrocraft E240/G240 type DC servo motors since they are plentiful, include an A/B/Z encoder and run from +48volts but like many, luck is not on my side as no solution seems to exist.
    If someone has a proven design I'd really like to consider it so contact me please.
    -- Dale
  9. #169
    Jan 2009
    334
    Re: dsPic-Servo
    Quote Originally Posted by dwalsh62 View Post
    -- Dale
    I have not vanished. If anyone is interested please contact me. the OPA549 is an operational amplifier and requires a split power supply. If anyone has interest then please let me know. Yes there are a lot of projects out there, but for high performance something other than a dspic or ARM STM32F type processor is needed. I have used the DsPic servo amps to mill all the conversion parts for the Denford NovaTurn Lathe and the parts for the AMD Gizmosphere 1 enclosure. You can see my work posted on CncZone and the Denford web sites.
    For serious applications, Texas Instruments processors should be looked at. AC Servo Drives | TI.com. They are high performance and have software for most motor designs, DC, AC, BLDC servos etc.
    I have gathered components and info for a upgrade to the OPA549. It is a TLE 6209 R (Delivers up to 6 A continuous and 7 A peak current, Operates at supply voltages of up to 40V).
    I could provide some help and circuit boards if the interest is high.
    Currently busy upgrading the NovaTurn, iBOB2 and AMD GizmoSphere 1, PathPilot.
    If anyone is interested please let me know.
    Hope this helps,
    Iron-Man
  10. #170
    May 2006
    2420
    Re: dsPic-Servo
    -- Dale
    The Elm Chan servo drive works well for the electrocraft servos, I have them on my router and have never had a problem.
    ELM - DC Servomotor Controller
    That is about as cheap as you can get for a DIY servo drive.
    Another option is this one, that also does BLDC, I am going to try build one myself, time permitting...it is derived from the original dsPIC servo and MAX MODs version.
    https://www.vbesmens.de/en/positioning-controller.html
    Good luck.
    Russell.
  11. #171
    Jan 2007
    93
    Re: dsPic-Servo
    Quote Originally Posted by MaX-MoD View Post
    Hello,
    I apologise for that long silence, I've been quite busy.
    The source is here : dspic-servo-26-Oct-2008.zip
    and the KiCAD project (TO220 MOSFET, NCP5106 driver, no SMT parts) : V1.zip
    And finally the manual, in French : YAPSC-Manuel
    PS:
    Forgot to say the board runs fine. I don't think there will be any other improvements, maybe just error loop between controllers (all controllers stop in the cas of one detects a MaxError event reached)
    I am planning a smaller, simple board without power stage, in order to control +-10V servo amplifiers directly.
    I am also starting the native 3 phase controller for AC and BLDC :rainfro:
    Anyone has got these files? I need them .
  12. #172
    May 2005
    1397
    Re: dsPic-Servo
    Quote Originally Posted by epineh View Post
    :cough:
    http://www.cnczone.com/forums/open-s...en-source.html
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
Page 9 of 9 789
  1. Replies: 0
    Last Post: 02-07-2014, 01:29 AM
  2. help me with dspic 30f4012 project
    By caligroup in forum Community Club House
    Last Post: 08-16-2010, 03:59 PM
  3. first steps with dsPIC + IRAMS AC servodrive
    By andy55 in forum Servo Motors / Drives
    Last Post: 07-10-2007, 07:55 AM
