585,762 active members*
4,085 visitors online*
    Nov 2017
    9
    Mach3 Mill DRO Question
    Setting up new machine utilizing Mach3 with Screen set 2010 for cnc router. I calibrated the axis utilizing the axis calibration on settings screen. When I type X .5 in the MDI line and spindle moves, the DRO reads .4999 “instead of .5”
    How can I correct this issue?
    Thank you!
    Re: Mach3 Mill DRO Question
    You can't. It's a rounding issue with your steps/unit. It has no effect on distance traveled, and only affects the display. The actual distance traveled is always to the nearest step, and is never rounded.
  1. Mill turning (using mill like a lathe) in Mach3
    By SwampDonkey in forum Mach Wizards, Macros, & Addons
    Last Post: 12-28-2012, 04:38 AM
  2. Mill turning (using mill like a lathe) in Mach3
    By SwampDonkey in forum Mach Software (ArtSoft software)
    Last Post: 12-08-2012, 03:00 PM
  3. Mach3 Question
    By binfordw in forum Benchtop Machines
    Last Post: 12-14-2010, 10:09 PM
  4. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
  5. Replies: 4
    Last Post: 06-19-2007, 09:43 PM
