585,992 active members*
5,238 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Switching Power Supply Stepper Motor
Results 1 to 6 of 6
    Hello community.
    I would like you to guide me which brands of switched sources are the most reliable, the idea is that it manages to deliver the power that it really says. Can you give me reliable brands?
    For example I know the MeanWell brand, I would like to know more alternatives to this brand, or to know if this type of switching sources have some type of certification such as PC sources.
    The idea is to buy on any of the pages such as Aliexpress, Alibaba, ebay, etc.
    I would be grateful if you could help me. Thanks
    15362
    Re: Switching Power Supply Stepper Motor
    Quote Originally Posted by Andrewxxd1 View Post
    Hello community.
    If you know the MeanWell brand then stick with it you won't find anything better in a SMPS without spending a lot of money
    Mactec54
    Perhaps a more expensive but reliable brand, that comes with some certification, the idea is that it is as close as possible to the power it indicates.
    The idea is to have a robustness that a linear power supply has. Some certification such as computer sources
    15362
    That's not going to happen no matter how much you spend, a linear power supply is always superior in terms of robust, but very inefficient alongside a SMPS
    The MeanWell output voltage is adjustable so you can output the exact voltage you want and they maintain it very well
    Mactec54
    Thanks for answering.
    But this type of switching source, in your experience, do they vary their voltage when taking them to the limit? for example if I have a 48V 10A stepper motor, and I get a source with the same characteristics. will there be a voltage drop when taking it to the limit?
    Perhaps the solution is to oversize it, but if so, how much would it be necessary to oversize it by 25% or more?
    These dimmable switching sources such as MeanWell have some type of certification as well as computer sources ?.
    24221
    I have Never used a SMPS for any systems I have put together using either steppers or servo's, for one, a regulated supply is not needed, the linear supply of the right construction is virtually bullet proof.
    You may notice that manuf. such as Gecko advise on a linear supply also.
    Al.
    Albert E.
  1. Power supply to stepper motor
    By raychar1234 in forum Stepper Motors / Drives
    Last Post: 03-09-2012, 02:03 AM
  2. Stepper motor power supply
    By naveen.a019 in forum Stepper Motors / Drives
    Last Post: 06-10-2011, 06:16 PM
  3. Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:50 PM
  4. Power supply for stepper motor
    By gaga2410 in forum Stepper Motors / Drives
    Last Post: 11-09-2007, 12:42 AM
  5. help on stepper motor power supply
    By ahmed in forum Stepper Motors / Drives
    Last Post: 06-14-2005, 05:56 PM
