585,959 active members*
4,841 visitors online*
IndustryArena Forum > Manufacturing Processes > Turning > NEED ADVICE - grooving OD
    Jul 2020
    7
    Hello all. New to cnc machining, need some expert advice.
    I want to turn a groove in a 1.5” mild steel shaft, 0.5” deep, 0.5” wide. I’m using a Sandvik grooving/parting insert. What is a good starting point for speeds and feeds when I’m doing this? Recommended spindle rpm? Any help is appreciated.
    Dec 2013
    5717
    Re: NEED ADVICE - grooving OD
    I guess I would start at about 200 SFM for the spindle, maybe 0.005 IPR feed. You will most likely want to use constant surface speed. Peck feed.
    Jim Dawson
    Sandy, Oregon, USA
    May 2007
    1003
    Old thread, but in an attempt to help others....do you have a Sandvik catalog? Feeds and speeds will be listed. Absolutely use G96. 200 SFM is way slow for that material. Do you realize that you can also turn with some Sandvik groove tools? Depending on material and tool, I don't always make a cut full depth, but will break it into 2-3 sections depending on the previously mentioned conditions.
  1. ID Grooving Issue
    By tcovington in forum CNC Tooling
    Last Post: 07-26-2016, 03:34 PM
  2. Grooving toolpath strategy advice
    By Robert M in forum Mastercam
    Last Post: 02-17-2015, 01:40 PM
  3. axial grooving; Oi-TC
    By Fräsling in forum Fanuc
    Last Post: 10-09-2011, 06:56 PM
  4. Grooving HELP!
    By modeltruckshop@ in forum Uncategorised MetalWorking Machines
    Last Post: 04-23-2009, 02:49 AM
  5. What is the G code for Grooving? Not G75?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 04-22-2007, 11:07 PM
