585,949 active members*
3,989 visitors online*
    Sep 2020
    Talk me out of this Chinese Mill?
    I would like to cut some brass/aluminum and came across this https://www.aliexpress.com/item/33008529077.html
    I was holding out for the new bantam tools machine but was a little unimpressed for the price. I am comfortable tinkering around and have already build a modified Seninci LongMill for wood. I am also playing around with the idea of a 6040z base and add servos/spindle. I just need one dimension to be at least 400mm any ideas?
    15362
    Re: Talk me out of this Chinese Mill?
    Quote Originally Posted by heemid7 View Post
    That is a good solid mill if it has the travels you need you won't fine anything better for the money and is way better than any 6040 will ever be it's all cast iron to start with
    Mactec54
    Sep 2020
    Thanks for the response. Have you seen anyone with one on the board or other places?
  1. Replies: 6
    Last Post: 08-19-2015, 08:08 PM
  2. Talk about the Development of Straw Pellet Mill
    By logia in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 04-03-2015, 10:08 AM
  3. lets talk bearings (Mini Mill x2)
    By ZipSnipe in forum Mechanical Calculations/Engineering Design
    Last Post: 05-03-2013, 06:57 AM
  4. Chinese Mill + Chinese accesory + Newbee = Problem
    By csaw in forum Benchtop Machines
    Last Post: 01-24-2010, 05:39 PM
  5. Chinese mill
    By Mr Bits in forum Benchtop Machines
    Last Post: 12-09-2006, 07:34 PM
