585,766 active members*
4,468 visitors online*
Results 1 to 2 of 2
    Sep 2014
    15
    AMADA No. 2010 Press Motor Off
    Can anyone help?
    Machine : Vipros 357
    Controller : amadan 04PC
    Initially after installing the Servo Valve, we had problem performing forming operation. Before the installation of servo valve ,the bottom position for the forming tools is usually around 5.00-8.00 on the PHNC parameter screen .But now i have to adjust it to 0.05-0.1 and even need to reduce the die height to get the forming done.
    Secondly, due to COVID 19 issue, this machine have not been operating since March 2020 till now. When we turn on the machine at the first day, the alarm "No. 2010 Press Motor Off" appear and the machine is not working. After rebooting, it can proceed to punching again. During the next few days of operation, this alarm appear frequently, affecting the status of my works.
    Can you assist on advising us what is the possible problem?
    Richard
    Jul 2020
    7
    Re: AMADA No. 2010 Press Motor Off
    Quote Originally Posted by richxantan View Post
    Can anyone help?
    Richard
    Hi Richard,
    Kindly check the parameters from 4020 to 4030 these are the optional parameters, hopefully, your problem of the alarm "No. 2010 Press Motor Off" will get resolved.
  1. Amada Press Brake
    By Footballwr46 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2018, 03:29 AM
  2. Replies: 1
    Last Post: 02-27-2018, 05:08 PM
  3. Amada PRESS BRAKE HFT 220-3
    By M7MED in forum Bending, Forging, Extrusion...
    Last Post: 12-30-2011, 03:04 AM
  4. amada break press
    By mike 82 in forum Bending, Forging, Extrusion...
    Last Post: 06-02-2011, 11:45 AM
