585,975 active members*
5,087 visitors online*
    Sep 2020
    Chinese 6090 4Axis 2.2KW
    Hello everyone!
    I am about to buy a CNC machine for my workshop, I am interested in cutting hardwoods and aluminum mostly.
    I have prior experience with CNC machines but very big ones as I was working as a shop manager for a university.
    I want the CNC to occasionally make bases for my products, or prototypes for machines I make like 3d printers and custom extruders.
    I wont be using the CNC everyday so I don't think a professional expensive CNC is the right choice for me.
    I was looking into Openbuilds, Workbee and Lead CNC but they seem to be more of an entry level hobbyist machine with a weak noisy spindle which I soon would have to replace.
    Doing some research I came across the Chinese CNC machines like the 4060 and 6090.
    I am interested in the 6090 with a 2.2kw water cooled spindle, ballscrew drive system and Mach3 USB controller.
    https://www.aliexpress.com/i/32858051279.html
    I was hoping someone here has purchased this machine and has some real feedback to give me.
    In any case any feedback is very welcome.
    Thanks in advance!
    Yiannis
    Re: Chinese 6090 4Axis 2.2KW
    690 2.2kw spindle process solid wood ok .
    process aluminum , suggest bigger power spindle ,constant type water cooling ,mist sprayer , some one add water cooling and water chanel ,if you main process aluminum.
    water cooling spindle cut aluminum
    Omni water cooling spindle cnc router cutting aluminum - YouTube
    https://www.youtube.com/watch?v=CHrhKwt1ArU
    https://www.youtube.com/watch?v=27ZHRsmpkYw
    How use 1325 6kw constant water cooling spindle to cut 3mm thickness aluminum panel
    https://youtu.be/MnqL_N5J2Qc
  1. 6090 Chinese machine on the bay.....
    By cnc Rookie in forum Chinese Machines
    Last Post: 02-16-2019, 06:19 PM
  2. 6090 chinese cnc router
    By elephantcnc in forum Chinese Machines
    Last Post: 01-22-2019, 09:17 AM
  3. share to you. About the Chinese 4axis cnc router
    By UnionTech in forum Commercial CNC Wood Routers
    Last Post: 05-23-2018, 04:11 AM
  4. Chinese 6090 on Richauto DSP
    By andrewdenhaan in forum Chinese Machines
    Last Post: 01-07-2016, 07:41 AM
  5. What Chinese 6090 CNC Router to buy
    By Pete 161 in forum News Announcements
    Last Post: 10-30-2013, 09:56 AM
