585,931 active members*
3,605 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Spindle orientation failure
    Feb 2016
    9
    Cincinnati Milacron Arrow 750, A spindle motor went out. I pulled one from another machine but I cannot figure out how to get the alignment right after several attempts.
    Right now on M19S0 it just sits there and chirps about 4 times per second and then displays the following alarm:
    Spindle Orientation Failure
    The control has not seen the spindle orientation feedback signal. (CR_OR_COMP) or NCEE signal N1SPDL_CHG.
    Please help.
    Re: Spindle orientation failure
    Quote Originally Posted by NationalAutomat View Post
    Please help.
    The spindle encoder may need to be reset to zero.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Mar 2008
    285
    Have you matched the Motor Part Number;
    MEG-OHMed the motor and checked the ohms;
    verified that the M11 Contactor is picking up and that the Contacts are not burned up?
    What was bad on the old motor?
    Are you getting Alarm LED on the spindle drive, or any blinking LEDs?
    Fives-MSI offers Tech-Support, Parts and Service on this machine.
    1-800-934-0735 Tech-Support-Cincinnati
    Tengo un problema con un control Sabre 750 A2100 al que se cambió el codificador del husillo que controla la orientación ahora cuando la referencia genera la siguiente alarma 44-6 Falla de alineación de cuadrícula del eje C que creo que se debe a que el husillo no está orientado quería saber cuál es la forma de recalibrar el encoder y la orientación del husillo de antemano gracias.
    [email protected]
    - - - Updated - - -
    Quote Originally Posted by cncmakers001 View Post
    [email protected]
    Dec 2006
    584
    I am assuming you have the black KOLLMORGAN drives. IF you can't orient the spindle then you can not complete the alignment process for the C axis. When you changed the spindle motor the orient point is not the same as the old motor. You may have incorrectly wired the resolver for the spindle, you can not assume the motors are wired the same. You need to adjust the SINE/COSINE settings in the control to match the new motor. You will also need software on a laptop to plug into the spindle 9 pin RS232 port to adjust the orient position of the spindle.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
  1. Spindle Orientation
    By Will_0000 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-01-2013, 03:29 PM
  2. VMC40 Orientation Failure
    By rdoty in forum Fadal
    Last Post: 02-11-2011, 04:49 PM
  3. Fadal Orientation failure
    By Paul Petersen in forum Fadal
    Last Post: 11-15-2007, 04:29 PM
  4. Spindle orientation
    By StampCraft in forum Haas Mills
    Last Post: 11-11-2007, 12:31 AM
  5. Spindle orientation
    By jimecv in forum Daewoo/Doosan
    Last Post: 11-09-2007, 06:25 PM
