Originally Posted by
jcsb
I am stuck on trying to find out what is going on with this combo. I'm hooking up the servo drive and communications cable and getting a E11 error, which is "phasing not correct". This has happened on two separate motors and drives. I've checked the wiring many times. I've tried changing the orientation of UVW to see if I can get anything else. Nothing is getting me there. I should note that I'm a retired mechanical engineer so while familiar with servo drives I'm certainly no expert. Both drives and and servo's were purchased used but have checked out for shorts, continuity, and such. Does this setup require me utilize a program to set up the servo to remove the E11 error? Any help would be greatly appreciated.
Thanks,
John
