585,930 active members*
4,089 visitors online*
Results 1 to 3 of 3
    Dec 2020
    HAAS Ethernet connection
    Hi all. Looking for some help on connecting a Haas mill over Ethernet. I know zilch about machining/CNC, but have been asked to try and connect a marking machine to a Haas mill. We’ve got the addressing sorted out, but the problem APPEARS to be that the Haas requires a username/password as though logging onto a PC/domain, whereas the marking system is just a straight TCP/IP address and port connection. The Haas will Dorint to a PC, but we can’t get a simple connection to the marker. Anyone got any (detailed) hints?
    Thanks very much in advance. Foggers
    Aug 2009
    1573
    Re: HAAS Ethernet connection
    Dec 2020
    Hi Machineshop5. Apologies for not thanking you sooner. I've been off on a couple of other projects. Thanks for that link. While it fundamentally follows what has been found already, it did identify that the Haas can be logged onto as server, rather than the Haas doing the client connection. As a result of that, I think it will also accept a Telnet connection, which is getting even nearer to what we need.
    I'll continue digging.
    Cheers
    Foggers
  1. Haas GR-510 ethernet to wifi connection success
    By cncpedro in forum Haas Mills
    Last Post: 04-10-2019, 02:35 PM
  2. Ethernet connection
    By Suffolk miller in forum Bridgeport / Hardinge Mills
    Last Post: 02-05-2014, 02:15 AM
  3. ethernet connection
    By brentpinfold in forum Fanuc
    Last Post: 09-19-2013, 12:36 AM
  4. ethernet connection
    By cwcw in forum Haas Mills
    Last Post: 04-07-2011, 04:12 PM
  5. Ethernet connection
    By edufer1 in forum Fanuc
    Last Post: 07-01-2008, 03:15 PM
