585,981 active members*
4,059 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Syntec 6MB error messages:1 NC Program L7 exceeds software or hardware limit etc.
    Apr 2014
    15
    Regarding Syntec 6MB I am having difficulty with error messages. Have anyone come across a "Coordinate 40 1 NC Program L7 exceeds software or hardware limit" error before? It accompanies a "Motion 18 Z Axis First Negative software limit exceeded" error. The latter, I believe can be fixed by MPG-ing with F3 held depressed, although the alarm (both of these, actually) occur when the spindle is well below the limit switch at top of allowable Z travel. I'm guessing the machine will be fine once knowledge of how this is set straight is found.
    Aug 2019
    6
    How did you fix this error? I have exactly the same problem
    Quote Originally Posted by 2C3D4U View Post
  1. X Axis First Negative Software Limit Reached - Syntec 6MA
    By cripk8 in forum Chinese Machines
    Last Post: 08-02-2019, 06:26 PM
  2. SYNTEC EZ4 Z-Axis Hardware Limit
    By Mol_Mott in forum CNC Machine Related Electronics
    Last Post: 10-25-2018, 05:21 PM
  3. Syntec software limit exceeded
    By Bascil in forum Chinese Machines
    Last Post: 01-16-2018, 03:11 PM
  4. Hardware Limit Error
    By jhwatts in forum LinuxCNC (formerly EMC2)
    Last Post: 07-22-2009, 04:33 PM
  5. SABRE- Y AXIS EXCEEDS HIGH LIMIT
    By crushmundy in forum Cincinnati CNC
    Last Post: 01-30-2009, 05:42 PM
