547,566 active members*
2,408 visitors online*
Results 1 to 2 of 2
    Registered
    May 2012
    52
    Reduced power, mirrors?
    Been a long time since I needed any power. Only done a few rubber stamps. Laser dont get used much.
    I tried to engrave a stainless tumbler yesterday and I noticed the power is way down. Tube seems to be fine.
    But look at this one mirror. Thinking of some 25mm si mirrors.
    Dennis
    Registered
    Dec 2006
    122
    Re: Reduced power, mirrors?
    Quote Originally Posted by 34ford View Post
    eBay has mirrors available, as do many online stores. If you want to confirm that the mirror is the problem (because other mirrors may also be bad), you can run a test. You could set the laser to pulse for a set period of time (like two seconds), and burn the raw beam into plastic (or any material). Do this before, then after the mirror. Then, compare the two burns. If there is a significant difference then the mirror is deflecting or absorbing excessive energy and should be replaced. If you feel motivated, you could get a CO2 laser power meter probe and use it to measure actual wattage before and after the optic (and also check the tube's output power prior to the first mirror--to see if it needs replacement).
  1. Reduced power under certain circumstances
    By Jimjamlaser in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 10-21-2019, 04:25 AM
  2. Issues with reduced power output on CO2 laser engraver
    By JohnnyMor in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 07-05-2018, 04:59 AM
  3. 50w Laser Issue - Reduced power, advice needed
    By Devoreg in forum Tormach Personal CNC Mill
    Last Post: 04-28-2016, 01:47 AM
  4. Reduced power for a 60W laser machine
    By daveswargames in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 03-30-2016, 04:47 PM
