585,877 active members*
3,968 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Cannot change parameter 340/341 - Pega 357 04P-C
    Sep 2020
    Hi all
    Had an issue with an accidental memory wipe (DO NOT hold zero/delete whilst powering on! in a bid to clear alarm "memory clear required")
    Thankfully, had the sense to create a backup tape file (machine.t and pc.t) so do have access to all the parameters. I'm able to set PWE to 1 and change almost every parameter manually, however the 2 that set the input and output device will NOT change. Tried from the SETUP page with not change and also from parameters 340 and 341 (which I read on this forum).
    Is there an access level I need to unlock??
    Sep 2020
    Re: Cannot change parameter 340/341 - Pega 357 04P-C
    Just to add, I'm using a program called Code Shark. Although the backup was done using Code Shark, and I can open the .T file, nothing appears on the screen. If I open it in notepad, all the P and N data is there.
    What do you guys use to transfer the .T file back to the 04P-C ?
    Sep 2020
    Slow progress - I entered parameters N000 through N0010 as well as N0300 through N0312
    This somehow allowed me to access and change N0340 (INPUT) and N0341) OUTPUT.
    Once I did this, set the machine into READ mode (SETUP, > button, then P-9999 READ)
    With the READ flashing, I sent the backup file and all appeared to have gone in - there were 7 blocks not sent.
    I not get alarms:
    240 +C OT
    417 X SERVO DGTL PARAMETER
    427 Y SERVO DGTL PARAMETER
    447 C SERVO DGTL PARAMETER
    Have double checked 8100-8124 (X-axis), 82xx (Y-axis) and 83xx (Z-axis)
    I assume 84xx is for the C axis but not sure
    Any ideas?
  1. Replies: 7
    Last Post: 03-29-2019, 05:20 PM
  2. Replies: 5
    Last Post: 05-19-2015, 10:42 PM
  3. change parameter
    By oaseone in forum Fanuc
    Last Post: 10-18-2011, 04:53 PM
  4. pega 244 fanuc 6m parameter
    By l_duh in forum Fanuc
    Last Post: 12-02-2006, 03:35 AM
