584,866 active members*
4,985 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Weird pattern on Z axis
    Hello to all the forum, this is my 1st post in here.
    I have a problem as the title states the weird surface pattern. It is every 4-5mm as the pitch in ballscrew. Please check attachment.
    First pass was with 1mm stepdown and 0.7mm offset. Second pass was with constant Z strategy with 0.1mm stepdown. Same pattern appears in radial strategy with 0.06mm stepover. Off course second pass was a ballnose endmill.
    I played we tolerance in solidcam but made no difference.
    Apr 2004
    5728
    Re: Weird pattern on Z axis
    It's suggestive that the ripples in your part surface match the pitch of your ball screw. Have you checked it for mechanical issues, like a loose nut?
    Andrew Werby
    Website
    Quote Originally Posted by awerby View Post
    Thank you for your reply. I have disassembled cleaned lubed the z axis 4 times. Some behavior. I also installed the polyurethane couplers ( old was spring type aluminum) nothing changed.
    Only thing i can think of is the ball screw is bented somehow. I don't have a way to know.
  1. 4th axis weird behavior
    By Gerry Kmack in forum Tormach Personal CNC Mill
    Last Post: 01-24-2016, 09:37 PM
  2. Weird issues with random axis
    By keithmcelhinney in forum Novakon
    Last Post: 07-30-2015, 02:53 PM
  3. Weird 4th axis issue. . .
    By brianbonedoc in forum Novakon
    Last Post: 02-07-2015, 01:23 AM
  4. Z axis acting up weird.
    By adamski07 in forum DIY CNC Router Table Machines
    Last Post: 10-12-2012, 12:44 AM
  5. weird axis fault
    By BMF in forum Fadal
    Last Post: 06-18-2009, 09:12 PM
