585,933 active members*
3,937 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Removing steel screws broken off in spoilboard
Results 1 to 9 of 9
    Nov 2008
    522
    Well, only days after installing spoilboard, someone used long, crappy steel drywall screws and busted one off deep in the table. Head's gone and shank ends about 1/4" below the surface. They tried to excavate it but only succeeded in digging a larger hole around it, but there's not enough room to get vice grips around it and needlenose don't have the leverage. It will probably destroy the resurfacing bit. It's not a situation for a broken screw extractor, that would just slide off. As would a drill. Well, I might use the CNC spindle with an endmill, but it's steel, and I don't know how long that screw is, I could end up making it harder than ever to retrieve the whole thing.
    Any genius ideas for removing it? I thought of wetting the MDF (it already has a trench dug around it where they tried to dig it out). The idea being that it will turn the MDF to mush so the screw might come out, but I expect all it will do is ruin the MDF. I thought of maybe taking an aluminum arrow shaft, cutting teeth in it, and using it as a long hole saw. It's an interesting idea but I don't think the "teeth" would be strong enough. Maybe a thin-walled steel tube but I can't think of a convenient source.
    Would an external stripped-bolt-removing cup work? I don't have a set of those, and this seemed much smaller than I remember the ones I have seen being. Smallest external is listed as 1/4", but I think that's the minor diameter inside (not sure), and that may be too large to grab that drywall screw shank.
    Apr 2007
    273
    Re: Removing steel screws broken off in spoilboard
    maybe use an end mill to to cut a pocket around it big enough to get a pair of vise grips on the end of it and get as close to the screw as possible or maybe all the way trough it and once its out cut a plug and glue the plug in the hole then surface it.
    Dec 2003
    1223
    Quote Originally Posted by machinedude View Post
    This would be my solution too.Then I'd hide the steel screws and leave a box of brass screws in the workshop.
    Nov 2008
    522
    Quote Originally Posted by routalot View Post
    Initially I did state that only brass screws were to be used. However, the brass stripped and busted all over. It's also difficult in that there are many more brass-plated cheap steel screws around than there are true brass screws.
    I think Kreg washer-head square-drive screws intended for their pocket jig have a sturdy construction that comes in and out very easily, except that it does swell the top surface that persists after removal unless the spoilboard is predrilled, which is unlikely to get people to work out and use consistently.
    Teks self-tapping washer head lath screws also seem sturdy. It's a Phillips head though. When used correctly, it's pretty hard to strip Teks, but there are a lot of looks-like-Phillips-but-isn't drive bits out there that are easy to accidentally use and the wrong bit can strip it easily.
    Jan 2007
    626
    1. RC hobbists use brass tube. Cutting teeth into the end of one of them might last long enough to cut a plug around the screw?
    2. Touch the screw with a arc welding rod and then use the rod the unscrew the offender?
    machinesdude's idea sound good as well.
    Aug 2009
    1573
    ..might work for ya. grind a slot for a screw driver
    Attachment 448780
    Nov 2012
    1267
    I would take a 1/8" endmill and route a small hole through the spoilboard around the broken screw. Then you can plug and resurface the hole if you like.
    Apr 2004
    5737
    We used aluminum nails to hold down out spoilboard; I was grateful for that when a project went a little too deep and I didn't wreck my cutter. Yes, just chip out around the offending screw until you can grab it with the visegrips.
    Andrew Werby
    Website
    35538
  1. Removing Rust From Free Rusted Steel
    By mikeysp in forum DIY CNC Router Table Machines
    Last Post: 12-07-2016, 11:16 PM
  2. Removing large amounts of material fast in d2 tool steel
    By jimmyjames1981 in forum Material Machining Solutions
    Last Post: 09-11-2014, 05:29 AM
  3. Drilling and Tapping into Steel Screws
    By jheers in forum MetalWork Discussion
    Last Post: 02-22-2013, 06:19 AM
  4. Removing broken drill
    By plastibob in forum MetalWork Discussion
    Last Post: 09-24-2009, 02:34 PM
  5. Removing steel with corncob rougher?
    By Rich05 in forum MetalWork Discussion
    Last Post: 06-25-2008, 05:15 PM
