585,715 active members*
4,457 visitors online*
Results 1 to 2 of 2
    Jan 2010
    3
    Old Precix controller replacement
    I am a novice at this, I have a 23 year old Precix router and the "controller" I use that term to include everything in the black box, needs to be replaced, (it constantly loses data and I can't use it anymore). So I could really use some help please guys.
    I originally planned to buy one of the kits from Ali Express but I find that the spindles on my stepper motors are 9.7mm and the NEMA 34's are at least 12mm+ . I would have bored the cogs out to take the new spindles but there isn't enough material. The mounting holes for the existing SM are the correct size for NEMA 34 motors.
    I think the existing motors appear to work ok, so I wondered if I could buy just the break out board, the 3 drivers and software etc. but I'm not sure exactly what I need and there are so many choices.
    Another option I might have is to make new mounting plates to take NEMA 23 motors . (I only cut and machine HDU, cedar, ply, PVC and occasionally thin aluminum sheet and the machine only runs 1-2 days per week.). I can get flexible linkages to go from 10mm-8mm. the big question is what do I need to buy in the way of controllers, drivers etc.I have to make sure everything will work together OK
    I live a long way from any major city and can't afford to spend $7-800+ just on some one coming out to look at my problem. So any help at all will be very much appreciated.
    Feb 2011
    26
    Re: Old Precix controller replacement
    Did you get it sorted out? I switched to LinuxCNC:
    Can see more details here: https://www.forum.linuxcnc.org/27-dr...recix-5x10-cnc
    I used the same motors though.
  1. Precix 11100Servo controller
    By antonyvm in forum Commercial CNC Wood Routers
    Last Post: 12-20-2015, 03:44 PM
  2. Looking for controller board for PRECIX
    By mtrobregado in forum Commercial CNC Wood Routers
    Last Post: 05-20-2015, 02:38 AM
  3. Convert/Retrofit old Precix HPGL controller to G-code
    By Blluitt in forum Commercial CNC Wood Routers
    Last Post: 01-14-2012, 05:42 AM
  4. Luminart (Precix?) Controller
    By ericdwilso in forum Stepper Motors / Drives
    Last Post: 05-01-2008, 12:42 AM
