585,753 active members*
3,714 visitors online*
    May 2009
    1332
    Can You ID this Motor?
    I have this motor in my box of electrical items but unfortunately I don’t remember from where I got it, most likely from an appliance. The markings on the motor housing are:
    ERS-5512SP-1583-K
    120/60HZ, NO:0910
    EVER MOTOR
    And on the face at the end of the motor is marked BV BR
    I know it is 120VAC and when I plug it spins quite fast after I push and hold the switch. I don’t understand the wiring connecting to the switch, looks quite strange to me.
    Is it possible to replace the switch with a regular ON/OFF switch? How, just remove the switch and put a new ON/OFF switch?
    Is it possible to add something to let it soft start (now it goes full speed instantly)
    Attached Thumbnails Attached Thumbnails Small AC Motor1.jpg   Small AC Motor2.jpg
    Nicolas
    Dec 2013
    5717
    Re: Can You ID this Motor?
    Looks like a vacuum cleaner motor or something like that. It's a brushed universal motor. A router speed controller should control it.
    http://www.evermotor.com/link/ac47.html
    Jim Dawson
    Sandy, Oregon, USA
    May 2009
    1332
    Thanks Jim for your time, I do have a router speed controller and will give it a spin
    Nicolas
