586,009 active members*
4,728 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Your experience using closed loop steppers on Sieg X2?
Results 1 to 9 of 9
    Dec 2005
    436
    I am hoping to get a poll of peoples experiences putting closed loop steppers on a Sieg X2 mill.
    Can you summarize what you have done,your recommendations and what are your lessons learnt?
    Aug 2006
    671
    Re: Your experience using closed loop steppers on Sieg X2?
    well I certainly don't use them on an X2, but I have been using closed loop steppers on my RF45 for many years now.
    Pros:
    - no tuning, plug them in and they work
    - positioning error alarms. I have mine wired so that if any steps are lost on any axis it throws an estop and will likely save your part from being ruined. It's saved me a few times.
    cons:
    - a little pricey and dated verses some of the AC or DC servos available today.
    - position feedback comes off the motor itself and will not account for backlash in your system.
    overall, they are significantly better than regular steppers, but if you have the money i'd go right to some clearpath or DMM motors.
    Dec 2005
    436
    CS900 I'm looking at the closed loop steppers because they are economical and the next step up in accuracy from my current open loop steppers.
    Which configuration do you use and why ( drivers local to the motor or remote)? I don't see a difference in the specs, is there one?
    Aug 2006
    671
    Mine are remote drivers. They were the only kind available when I bought them.
    I wouldn't expect to see any increase in accuracy, they have the same number of steps/rev as regular steppers, but you will be able to know when you've lost steps.
    as far as specs, the motor torque and speed will be exactly the same as a similarly rated open-loop stepper.
    Dec 2005
    436
    CS900: So your remote drivers can tell you when you've lost steps but the drivers local to the steppers don't have that functionality.
    That is noteworthy, thanks.
    Jan 2008
    1529
    That's not what CS900 said.
    Dec 2005
    436
    pippin88: Where did I make a mistake?
    Jan 2008
    1529
    CS900 did not say anything about the difference between separate (remote) drivers and drivers attached to the steppers. (CS900 said the only ones available when they bought were the separate drivers).
    I would expect all closed loop steppers to have a fault output to signal to the controller when steps have been lost.
    Aug 2006
    671
    that is correct. I believe most all close loop systems have an error output signal in one form or another.
  1. Replies: 8
    Last Post: 10-19-2018, 08:47 PM
  2. Replies: 10
    Last Post: 07-03-2018, 03:45 PM
  3. JMC closed loop steppers - anyone have any experience?
    By Tripet in forum Stepper Motors / Drives
    Last Post: 11-10-2016, 02:49 PM
  4. Replies: 0
    Last Post: 09-15-2016, 10:54 AM
  5. Closed loop steppers
    By pstockley in forum Stepper Motors / Drives
    Last Post: 03-31-2006, 03:07 AM
